Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Green arches and now green flashes
After about a year, the TV started showing green arches, from the top of the screen they drooped down and from the bottom they arched up. They were not prominent but really noticeable when the picture was dark. Recently it started to flash green on the screen and will eventually shut itself off. I removed the wooden panel in the back to take a look and on the back of the green projector, the card has a light. when the TV flashes green the light comes on. It seems the card on the back of the tube might be faulty but wanted to verify this prior to trying to replace it. Has anyone else seen this problem? any input would be appreciated
  • 3 more comments
  • Jimbo Moore Oct 27, 2006
    Actually there is a bulb mounted on the card that lights up not the tube itself.
  • Jimbo Moore Oct 28, 2006
    When I first read the solution I was thinkingPick up a 57" TV is this guy nuts? but I lifted one side just a little and set it down "firmly" and it appears to have solved the problem with the arcing in the green tube. I still have the problem of the slightly visible green arches when the screen is dark but I can live with that unless someone knows a solution to that as well. Thanks for the input....
    Jimbo
  • Jimbo Moore Feb 10, 2008
    After 1 year it started again. Then last night, now it appears the green is out completely. is it possible the green tube is bad? When I look at the menu there is no green color at all and all the channels look red. How do I determine if the green tube is blown? Any advice would be greatly appreciated.
  • brpowell45 Mar 18, 2008
    i turn the tv on it go green then blank but has sound its a kp-57wv600
    any help
    contact me at brpowell45@yahoo.com
  • Jimbo Moore Apr 08, 2008
    Awesome explanation and great photos. Unfortunately my set has a bad green tube and no more adjustments will make it work. Italy Sony repairs are expensive so I will take it to the shop after I return to the US. Thanks for the informative link though.
    Sergeant:
  • 337 Answers
If you see a neon light in the crt board and it lights up is because the green picture tube is arking inside,the light is supposed to do that and is why is there,the only way to correct the problem is by replacing the picture tube and it can be costly sometimes,there is another way but this will not take care of the problem for good,it might go away for a while but it might return,is hard to tell if it might work,what you need to do is lift the set from the ground about 3 inches and drop it,sometimes just by doing it once it works ,other times it takes more than once,do not over do it or something else might break,is an option you dont have to take and you still have the option to replace the tube.Let Us know how it goes or if you need more information.
Posted on Oct 27, 2006
Testimonial: "Worked like a charm for about 6 months then started doing it again, guess I will be replacing the tube or giving it to my soon to be son-in-law"
  • Omar Urrutia
    Omar Urrutia Oct 27, 2006
    Your rating response is also important.
  • Omar Urrutia
    Omar Urrutia Oct 28, 2006
    The neon is suppossed to light up so the tube doesnt take the damaging ark,as far as the green lines I think the screen control for the green is a little too high,in the set there is a block know as high voltage distribution block and it has 6 adjustable controls 3 on top for the focus for each color and 3 on the bottom for the screen controls for each color,the block is about 3x3"square,do not touch the focus controls and need to find the one for the green screen control,turn it down just a little and the lines you see will disappear.Is something you can do easiely.Let Us know if you need more information.
    Problem Solver:
  • 11 Answers
This site explains the do-it-yourself fix -
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
It worked beautifully on mine - takes about 1/2 hour and a screwdriver
Posted on Apr 08, 2008
The top left of the screen is drooping down and is green,red goes across where green is drooping from.
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 28, 2011 | Hitachi 46F500 46" Rear Projection...
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Green hazy upside down arch of color across the screen
Your convergence board is in need of reworking on a component level or replacing the board! And you will most undoubtedly need to resolder the vertical IC and all ICs mounted on heatsinks on the power supply board. This TV is showing its age. You may choose to repair and that may last a year more or so! Good Luck and thank you for asking!
Jun 20, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
Red and Green Vertical Arches
CHECK ANY MAGNETIC MATERIALS ON THE CORNER OF THE TV.IT HAPPENS DUE TO MAGNETIC MATERIALS ONLY. SUPPOSE IF IT IS THERE KEEP AWAY FROM THE TV. AND THEN GO TO THE MENU OPTIONS AND SET AUTO DEGAUSSER ON.
Apr 23, 2007 | Philips 32PT8302 32" TV
No clue
Sounds like failures of the convergence output IC's. They should be STK392-110's in the set. Also check associated circuitry around them.
Mar 24, 2007 | Hitachi 43F300 43" Rear Projection...
Problems with green arching lines
yes there is a small black box with 6 controls on it, take off the bottom front of the tv, behind that you should find a black piece of plastic you can remove by taking out 2 more screws. the black box should be in the upper rhs.now i don't remember if the top 3 are the screen controls or the focus controls. the rows should be labled, you are looking for the screen control row. the green control is the middle one. you can try turning down the control till you no longer see the green lines. try adjusting in a dark room, it will be easier to see the lines & when they are gone. if you problem is not solved by trying this, then i agree with your tech & the green tube is bad. good luck.
Oct 23, 2006 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
133 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
