Question about Emerson Televison & Video
Cable connector pulled out of set
Tv fell off of stand while connected ripped off of the board can I replace the board how and where to get the part ..not sure what that box is even called
    Scholar:
  • 146 Answers
The box is called a tuner. You can not replace the "F" connector. It is to risky for a cunsumer. If you can solder well. Try and replace the tuner. If not take it to a repair center.
Posted on Nov 10, 2008
We didn't know that our son had sprayed febreez on the back of our LCD tv. When my husband turned it on it has vertical lines all across the screen and then everything goes fuzzy. Once I realized what had...
You probably have an LCD TV; if this happened to a plasma set, there likely would have been fireworks inside.
From the video symptoms, it appears some of the spray got into the T-Con (short for Timing Controller) board or the connections between that board and the display panel. I don't know what is in Febreze or whether it could corrode the components, or whether it could adsorb moisture on humid days and cause problems again after it dries out. At a minimum, unplug the TV so you can be sure there won't be electricity to accelerate any corrosion.
The T-Con is usually covered with a steel shield and has two wide ribbon cables connected to the edge of the LCD panel, and a cable made of twisted pairs of wires going to the main board. On most LCD TV sets, the T-Con board is located at the top center of the set, but some have on the bottom center. Remove the back of the TV and inspect for spray residue in this area (the TV must be unplugged, and be careful not touch the power supply board (the power cord wiring is connected to the power supply board) because it can hold a high voltage charge for as long as half an hour after it is unplugged.
If the T-Con board got soaked, the best thing is to remove it and wash it off with distilled water (it may be necessary to clean it with distilled water and dish soap mix, then thoroughly rinse with distilled water). Let it dry for three days or put it in an airtight container with dessicant or dry rice for at least a day - it takes that long for the water under the chips to dry out. The cables and connectors are rather delicate; you cannot just yank them out. The ribbon cable connectors have lock tabs that must be unlatched; then the cables disconnect easily (the cable ends probably need to be cleaned where they go into the connectors; if so, also very gently wipe off any spray on the edge of the panel in the connector area). The cable to the main board (called the LVDS, or Low-Voltage Differential Signal cable) has two shiny metal latches, one on each side of the connector. Gently squeeze those toward each other and pull the cable connector out of the mating shell on the board (avoid pulling on those tiny wires!). If you look up your TV model on the ShopJimmy website and find the T-Con board listed for the set, there will be a video on the part page showing how to remove and replace it. I strongly recommend checking out this video and the price of the T-Con board ASAP - it will help you decide whether to do it yourself or bail out and take it to a TV repair shop.
Note: the board can be damaged by static electricity from your fingers. Avoid touching the components or wiring traces on the board, just handle it by the edges. Do not set it down on a plastic surface, upholstery or carpet; these can carry static charges. Don't let your children touch the inside of the set while it's open.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 05, 2017 | Televison & Video
Service printhead error 114.02
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to "RIP Board" on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
"RIP Board" on page 4-11 If this does not fix the problem replace:
Yellow Printhead Assembly - Go to "Printheads" on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the "Printhead Adjustments" on page 4-1.
Feb 15, 2014 | Office Equipment & Supplies
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
56 inch tv
The T Con board at the top of the back panel has 2 flat cables that connect from this board to the main board. Check these connection. Be careful. Lightly sqeeze in on the sides of the connector and pull. Push cables back in. Check picture. an you get any graphic from the tv on the blank side. If you can then definatly Main board is bad. Other wise replace the flat cable (FLDS cable) on side that is missing video. next replace the t conn then next replace the panel. I think the t conn board on this set is part of the LCD panel. It is Likely cheaper to replace the tv if the panel is bad.
Mar 25, 2010 | Samsung LN55A950 55 in. LCD TV
I triped over the cable cord. Cable cord end that protrudes fron TV was broken off. need to replace it so I can get cable reception.Please Help .Other wise the T V was showing great.
I'm sorry to tell you this ... when this happened with the TV at work (a camp;ing resort), we found the "F" connection was mounted to a printed circuit board attached to the 'motherboard' of the TV. The board was more than $100.00. We bought a new board and the new kid got to it before I could and he mixed up the wires. After the technician was done with it, the bill was another $250.00.
What I can recommend to you to prevent future damage is dont connect the cable to the TV -- get a short piece of cable and fasten your TV to a "F" fitting stand-off which would be firmly mounted to non strategic part of your TV. Then connect the cable to the stand off. Next time it is pulled on, it will pull the end off your cable (fix for a couple bucks) and not tear the guts out of your TV.
The parts are probably available to you. Make sure you have the right parts in your hand before you do anything ... and then take lots of pictures and notes as you remove the old and insert the new.
I hope this helps you ...
a
Oct 08, 2009 | Televison & Video
I tripped over the coaxial cable which ripped the cable connection port out of the back of my RCA 27" tv. is there anything i can do?
Chances are that the cable was ripped off the connector. This is relatively easy to do but assuming that you have not done this before directions would be needed. Pls see this link for step by step instructions. Of course you would need to remove the connector at the back of the TV and see if you can still use that or purchase a replacement from any electronics parts store.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 19, 2008 | Televison & Video
Lexmark Colour C752 108 service printhead error
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
“RIP Board” on page 4-11
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
to perform the “Printhead Adjustments” on page 4-1.
Jun 03, 2008 | Lexmark C762 Laser Printer
I need repair parts
I get lots of parts from a company called MCM Electronics, and they offer a replacement connector. Here's a link:
http://www.mcmelectronics.com/product/215543&CAWELAID=220241622
This is an RCA part but can be used on nearly any TV where the connector has been ripped off. (Make sure to use a soldering gun when soldering the new connector to the metal shield in the TV. The small iron you would use for other connections won't get enough heat into the connection.)
Jan 14, 2008 | Supersonic FC2245 13 Color TV/DVD Combo...
I have a 27 jvc tv
The connector that just fell off when the cable was pulled will have to be replaced by a service center, Sometime the connector will just come out ot the solder joint and can be replaced. Sometimes it breaks off part of the circuit board, if it broke the board it is not likely that anyone will be willing to try to fix it.
Nov 29, 2007 | JVC HD-56G886 56" Rear Projection HDTV
1996 32 inch Panasonic TV
What you are calling the "antenna module" is actually the tuner. The connector that pulled out is called the F connector. The F connector can be soldered back onto the tuner but this is a very delicate procedure and is especially difficult if any of the coils in the area of the F connector have been bent, altered or moved. The tuner itself is not too expensive and is much easier to replace than trying to replace the F connector, especially if you have never done one before. If you use this set with a cable box then simply connect AV cables from the cable box to the TV set the TV to VIDEO.
Jun 27, 2007 | Panasonic CT-32G23 32" TV
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
