Question about Refrigerators
GE fridge water leak
All of a sudden the fridge sounds like its running water and its leaking from the bottom? The ice maker is working but the ice dispenser ALWAYS been frozen over. Anyone know what I can do to fix this? Its a GE side by side.
  • applewings Nov 10, 2008
    Thank you for the response. There was a pin hole in the hose. We cut it and rconnected it but it didn't work so we put a new connector and it was still leaking .. so for now, I cut the water supply to the hose and will call the GE rep tomorrow.
GE is a durable appliance and since you didnt provide more details you description states " the fridge sounds like its running water ". Thats good that means that the heater coil located within the walls of the freezer are doing their job. The water is traveling down to a drip pan under the fridge. This happens on a timed cycle in order to keep the ice from building up in the freezer compartment like it used to in the refridgerators long time ago.How well a job is it doing , maybe not so well ! Since you said " the ice dispenser is ALWAYS frozen over. That could be the freezer coil or it could also be the stop lever above the ice container which it is not telling the dispenser to stop producing ice.You can test it out by raising the lever to its upper most position.If it solves the over freezing then you dont have to replace it . But, In case you need to replace the motor assembly.Which is simple . First unplug the cable plugged into the back wall, and then remove the mounting screws.When you go buy the motor assemly be sure to take the BRAND, MODEL# , SERIAL# , DATE MFG which can be gotten from a plate on the inside wall And if that still freezes over unfortunately then the heater coil needs to be changed out by a tech which could be labor intensive (money wise that is). GE usually makes their product "owner friendly". You should ask the guy selling parts if he could show you an exploded view of where the heater coil is located and help give you tip on installing the coil. They have diagrams to show how and where it goes.Be sure and take note and sometimes the can help you over the phoneshould you run into a snag. At first it may seem difficult but once done you'll feel a sense of accomplishment and pride.
Posted on Nov 10, 2008
  • jravenus Nov 10, 2008
    Whenever you cut the hole out be sure to use a new brass coupling to insure a good seal because the old one has already been crimped. By the way in my sleep last nite I also thought of another reason why the freezer is " over freezing". It may also be because the seal around the door is not sealing tight enough and may be allowing air in which really doesn't matter much when you open the door but when its closed and the air goes in the air carries moisture in and that moisture sticks to walls, freezes and continues to build up. So check the seal for leaks. By using a sheet of paper close the freezer door leaving enough paper sticking out to be able to grab. Pull the the paper and feel the drag. Do this all the way around the entire seal. And where ever it is easy to pull out that is where the moisture goes in. Most of the time its quite evident where the leak is at.
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
I have an old GE fridge with ice maker in freezer, water started leaking and flooded floor of freezer and started leaking outside freezer. What's going on & how do I fix it?
I think you need a new fridge/freezer. Look for offers now on sale some are quite reasonably priced and home Depot has interest free credit.
Sep 19, 2017 | GE Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Fridge leaks water when Ice maker is activated by lifting lever
Either a loose or broken hose , or worse, a crack on the water valve.Pull fridge and check water valve and hose when signal calls for water.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
GE Fridge with ice maker. Water is slowly leaking
drain is clogh at the bottom of the freezer
Mar 29, 2009 | Refrigerators
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Refrigerators Logo
284 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
