Phaser 860n Service Fault 15.004.45:2249
Don't know anything about printer problems so any help is greatly welcomed and appreciated.
  • 1,314 Answers
Hello. This is the error code from the service manual:
15.004.45: TCD_Thermistor_Slow. Most likely cause is a failed drum heater.
Steps for replacement:
1. Turn off the printer and remove the power cord.
2. Remove the right cover.
3. Remove the left cover.
4. Remove the upper feed roller.
5. Disconnect the locking wiring harness from the right side ofthe paper/drum heater.
6. At the front of the paper/drum heater, remove the two screws securing the heater to the inside of the printer frame. Do not confuse the mounting screws with the nearby smaller brass colored assembly screws.
Part # 650-4228-00
Posted on Nov 10, 2008
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
High. I have just bought a Xerox Phaser 7300 Laser Printer and don´t fancy paying top end for the Toner. Does anyone know if I can refill/reset the cartridges? Thanks for any help.
you can refill the cartridges without having to reset anything. Many companies on the internet sell bottles of toner which are alot cheaper (eg uninet), you can also make override the imaging units by going into service diagnosistisc
May 20, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 8550 fault 26,962.64, anyone know how to fix this fault?
My 8560dn showed that message - it was not a heater or anything weird. I removed the waste tray; emptied it and re inserted - and rebooted the printer. it spent quite a while cleaning - but it prints fine now.
the waste tray was 'stuck'. To remove, I first removed the maint kit and then with a flashlight shined inside, saw there was a lever on the right side which, when I moved it, released the waste tray. Voila - road to success (and no service call). Have a spare set of ink on hand as it uses a bunch going through the cleaning process.
This turned a useless paperweight back into a productive member of my office society.
Nov 24, 2009 | Xerox Phaser 8550DX Laser Printer
On bootup of Phaser 8400 recieve fault 37,004.40:117545
PEST Fault 37,004.40: xxx
Printhead reservoir 0 disconnect:
Reservoir is not drawing the expected power from the power supply.
Service manaul states the the printhead needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 10, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8500 reservoir heater took too long 13,266.44 error
Most likely you have a bad print head. There is an outside chance that the electronics module is bad, but with the monitors acting as you describe, I would say the print head heater is malfunctioning of the sensor is defective. Either way you have to replace the print head. No uncommon.
Jan 20, 2009 | Xerox Phaser 8500/DN Printer
Print-head is shot... You'll need a new one, I see power spikes wiping them out quite often, Leaving your Xerox Phaser Solid-Ink printer on all the time usually isnt a problem.. but be smart about it... if a storm is comming or the forcast says lightning, shut it down :)
Jan 20, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200N hangs on warmup
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
Mar 07, 2008 | Xerox Phaser 8200 Laser Printer
Tektronix Phaser 850 Service Fault 13.019.40
Most likely a bad print heat. One of the ink heaters is overheating.
Oct 08, 2007 | Tektronix Phaser 860DP Thermal Printer
99 people viewed this question
