Question about Whirlpool LSN1000LW Top Load Washer
Agitator not working
I have a whirlpool washing machine Model #LSN1000LW0 Serial #CM4318687 and the agitator stopped working. It will not wash or spin. How do you fix this?
  • 1 more comment
  • Glaser Nov 13, 2008
    You were right on, thank you for your help!
  • Anonymous Dec 01, 2008
    Whirlpool LSN8233BW0 Top Load Washer Agitator problem
  • d_lindhorst Apr 14, 2009
    washer does not agitate or spin- fills with water, motor sounds like it is working, but no agitator motion. I can spin the agitator by hand- it clicks and is getting hung up on something, but moves, just not freely
    President:
  • Whirlpool Master
  • 2,651 Answers
You can put a serch in you tube for" motor coupling repair" simple enough procedure, easier to watch then explain... part number 285753
Posted on Nov 10, 2008
Whirlpool washer. the agitator just stopped in mid wash. there was heavy towels. . could the heavy towels have caused the agitator to stop.? does the agitator come off.?
the agitator cam be removed but that will not be the problem
if it has a belt drive , probably the belt broke or the agitator solenoid /engagement lever has broken
you will need the model and serial number when you call the technician for a proper diagnosis
May 14, 2017 | Whirlpool Washing Machines
Whirlpool model la5558xs agitator won't turn during wash mode
Replace the agitator dogs. Here is the part to order.
There is a video on that parts page to show you how to replace them.
Dec 03, 2012 | Whirlpool 3.2 cu. ft. Plus Washer
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
The agitator on my Whirlpool washing machine does move
The agitator has a set of dogs that are easily replaced. 71e0cea.jpgTake a look at these repair pix
Aug 20, 2009 | Washing Machines
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
How do I remove the agitator from a compact whirlpool washer model LCR7244DQ2, SERIAL VLG4923565, TYPE 113-01, ASSEMBLED IN MEXICO, AGITATOR PART # 1154680
Retaing bolt on this model is not on top. uses a 1/4 inch hex head screw about 12" down on the outside of the agitator.
Once removed agitator slides upwards off the drive spline. Gentle brute force may be required!
Jul 04, 2008 | Whirlpool Washing Machines
Whirlpool LSN1000LW Top Load Washer Logo
246 people viewed this question
Dan Webster
Dan Webster
Sal De
