Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Wireless not working
I can connect via and ethernet but the wireless capability quit working. Any suggestions - everything appears to be functional (radio is on, etc.) Have tried to reset but that was also unsuccessful.
    Problem Solver:
  • 4 Answers
Type http://192.168.1.1 into your browser window, this will take you to the Westell 327 router home page (your router). There are tabs across the top, select configuration>wireless>basic, that will take you to the wireless operation window which probably says disable. Click the drop down arrow to select enable, then click save at the bottom. From this same window you can enable/disable wireless encryption or change the wireless channel among other things. The default on this router is wireless off so if you pressed the reset button on the back, the wireless is probably turned off. You also will have lost your user name and password which you can re-enter from the home page, same address as above, (hopefully your ISP gave you them and you saved them somewhere). You should see Connection Overview in the middle of the screen, select profile editor, enter your user name and password in the appropriate boxes, check the box for always on and click save. This should restore the operation unless there really is something wrong with the router. They are usually pretty reliable.
Posted on Nov 10, 2008
I have a laptop which is hooked up to a wireless router (Belkin) and NOBODY can get my wireless kodak printer to work on this system including the tech who came out from the cable co.
How is this printer connected to your PC? If it's connected wirelessly, I would suggest connecting it through a wired connection (if is has Ethernet capability) and trying to install it again. Even if you need to relocate it near your router it may very well fix your problem. Most wireless printers have annoyingly poor wireless cards in them, resulting in problems. you would then install it as a network printer and you can access it from any PC's in range of the router.
If this not have an ethernet port, then I would try connecting it directly to a desktop PC (via USB), and you could share it with other network users. In my experience this works very reliably, with only one caveat: for print jobs to go through the connected computer has to be on.
Aug 04, 2011 | Kodak Office Equipment & Supplies
What is the difference between connecting a computer to a DSL modem via Ethernet and connecting a computer to a DSL modem via USB?
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
Sep 23, 2009 | HP Pavilion dv6000z Notebook
Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
May 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I can't hook my computer up to my phone line for internet. I have my router and another desktop hooked up to the phone line through the router.
That modem is in itself a router. However it only has one Ethernet port and no means of broadcasting a wireless Internet Signal which makes its function of a Router somewhat useless. What you need a(n) (wireless) access point. The Access Point will give you more Ethernet slots allowing more computers to be connected to the modem/router via CAT5 (Ethernet) cables. Depending on if you get a Wireless access point or not you might also be capable of using a wireless adapter to connect to the 2wire and get Internet access.
Let me know if I need to clarify any of the points above or if I can assist you further.
Mar 16, 2009 | 2wire 1800HG Router (RG1800HG00)
System cannot recognise wireless capability
http://www.pc-ap.fujitsu.com/support/lb_os_a6010.html
Hi !
Follow the link above, select your OS, download the files for wireless LAN, install them...and VIOLA! you will be fine!
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 16, 2008 | Fujitsu LifeBook A6010 Notebook
Linksys to homeportal
In order for you to make the linksys wireless router and the homeportal 1100 to work together they should be connected via CAT5/ethernet cable, you cannot connect them wirelessly...
Oct 26, 2008 | 2wire HomePortal 1100 Router...
Network problems connecting to internet
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
May 21, 2008 | Dell Inspiron E1505 Notebook
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
262 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
