Question about JVC AV27F476 27" TV
JVC 27 How do you turn up the screen adjustment a touch?
    President:
  • 2,992 Answers
Screen and focus adjustments are integrated into the flyback transformer. Take the back off the set and you should see the two little knobs on the transformer. A little tweak of the screen control (it may be labeled "SCREEN" or "G2") will brighten things up. Just be careful. Working on an operating TV, especially in the horizontal output area, exposes potentially lethal voltages.
Posted on Feb 06, 2009
Tv has no picture
try adjust screen in flyback, if you see a white line in bottom, the vertical ic have cold solder or is bad.
Apr 28, 2010 | JVC AV-27530 27" TV
Do you have the service codes for the JVC I'art AV-27F802? I have a set that has convergence & color calibration issues and I can't find the codes anywhere... Thanks
There is no much convergence adjustment inside service menu. Yes color it has RGB drive adj. but if not touch it will not change. Convergence mostly adjusted mechanically (check your purity magnet and yoke mounting). Hope it helps
Feb 10, 2010 | JVC AV-27F802 27" TV
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Tv to dark cant see nothing tv's to dim
On the back of the TV, to the right of the I/O panel, there are 2 vertical slot shaped openings on a raised bit of the plastic case. Behind the lower slot is the screen adjuster. Using a phillips screw driver, turn the adjuster clockwise to increase the brightness. Behind the upper slot is the focus adjuster.
Dec 27, 2009 | JVC AV-27D305 27" TV
I have a JVC 27'' AV-27530 TV that the picture is very dark
An aging FBT if it still can be adjust using screen adjustment on FBT that will be a small tweak.
But if you are inexperienced with this, asked someone who knows how to do it to fix it for you.
Apr 08, 2009 | JVC AV-27530 27" TV
The tv turns on, i can see picture but its too dark.
Try adjusting the screen control on the flyback transformer. It may be accessible without removing the cover . The access hole is usually on the back of the set and wil be marked "screens" Failing that please post the model number
Mar 12, 2009 | JVC AV-27530 27" TV
TV picture too dark
your screen adjustment needs to be turned up just a touch (flyback)
Aug 01, 2008 | JVC AV-27D302 27" TV
Jvc av 27530
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Dec 23, 2007 | JVC AV-27530 27" TV
Dark picture
**WORKS**
Nov 23, 2007 | JVC AV-27S33 27" TV
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
JVC AV27F476 27" TV Logo
81 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
