I have a older sony STR-DB830 receiver that keeps blowing two fuses labled f801 and f802. They are 125v 8amp. They pop the instant you turn the power on. Something is shorted, but I can't find it. Is this worth fixing? I have done some reading about this unit and it is suppose to be one of the better ones built.
  • Graeme Ross
    Graeme Ross May 11, 2010
    Do you have a multimeter to do some spot checks with?
    Sergeant:
    Champion:
  • 227 Answers
Hello, i believe that your problem is in the audio output ckt, check all the transistor you have one bad channel (shorted transistors). with a soldering iron disconnect them and check them with a meter.
good luck
caypianan@yahoo.com
Posted on Nov 10, 2008
I hooked up more than one set of speaker wires in on set of terminals and blew the 2 8amp fuses inside. i replaced them ,but they blow right away when i turn the system on.
Hi Robert,
You've probably managed to fuse two wires together or one wire onto the casing. You need to find and rectify this before proceeding further.
Jul 16, 2015 | Sony Str-av910 Home Theater Surround...
SONY RECEIVER MODEL STR - D315 keeps blowing a fuse
When the main fuse blows on a sony, it is usually caused by shorted output transistors. You would have to replace these transistors before the unit will not blow the fuse and power up correctly.
May 23, 2013 | Audio Players & Recorders
Hi I have a str-dh520 reciever that has a 8 amp 125 volt fuse that blew and I could only find a 8amp 250 volt fuse and when I installed it it blew right away. What do I do now? Dose it have to be a 125...
No! the fuse you replaced was fine, the power transformer may be shorted, or the audio ouput semiconductors are shorted, check the speaker wires for shorts, if okay! I recommend a pro with a estimate.
Mar 19, 2012 | Sony Audio Players & Recorders
I have to replace 2 fuses 8Amp 125volts from a sony reciever, but I can't find it to buy , do you know any site to order on line or if I could use 8Amp 250volts?
fuses have different sizes even though they have the same rating's, the best remedy to do is, do you any stranded wire, cut one piece out of the whole strand and solder it on the fuse housing that will do the trick.
Jun 09, 2010 | Sony STR-DE935
I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Feb 08, 2010 | Sony STR-DB930 Receiver
Sony STR-DE945 8A 125v fuses
Check HomeDepot they have 7amp , maybe your store has 8amp.
Dec 18, 2009 | Sony STR-DE945 Receiver
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Stuck protector mode
find out why the fuse blew in the first place.the protector is just PROTECTING the main circuits of the receiver.the receiver turns on just to confirm the power circuit is OK.
have it checked by an electronic engineer.
Apr 16, 2008 | Sony STR-DE597 Receiver
380 people viewed this question
 Grubhead
Grubhead
