Question about Sewing Machines
The needle to hook relation for a juki ddl-555
I have a industrial juki ddl-555 sewing machine. And I cannot get the hook on the for the bobbin to line up right with the needle. Any hints or clues. All attempts have the needle hitting the hook case and missing the hole. Contact me back @ sixmillboy@mac.com
SOURCE: juki stuck needle
check settings
Posted on Apr 28, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: My thread is breaking when
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
Posted on Mar 24, 2009
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
  • 20 Answers
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Posted on Oct 13, 2009
Hi I just purchased a used Juki DDL-555. 1) It will not catch the bobbin thread. 2) it will not sew forward and feed the fabric along (it sews in reverse just fine). Can someone please help?
the material movement is set by the forward/ reverse knob or lever
not picking up the thread can be needle thread tension too loose
it can be needle hook timing
Apr 20, 2017 | Juki Sewing Machines
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
My juki 8700 h frays thread while trying to sew
Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
Mar 26, 2014 | Juki DDL-8700 Industrial Straight Stitch...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
How to set timing and bobbin in my juki ddl-555
hi there
when you need to set timing please first make sure height of needle bar is ok. there's two mark at needle bar, the upper one is for height of needle bar: bring the needle bar at lowest position and in this case the upper mark must be equal with lower needle bar bushing.
second : set timing
move hand machine pulley at the same rotation and when the lower mark equal with lower needle bar pushing the tip of hook must be at the center of needle groove and just light touch not hit. that's all
best regards
ashraf abozid
CAIRO - EGYPT
Nov 29, 2012 | Sewing Machines
I have a Juki DU 141NH industrial sewing machine. I just had it serviced. I had to put a new bobbin in and now the needle is not catching my bobbin thread. Please help!
Be sure you have the proper needle - it is longer than standard needles, plus be sure that you put the needle in from left to right - not...front to back.
Oct 07, 2010 | Juki DDL-8300
What needle type is used for the juki ddl 555?
I use Organ needle in mine. You can find these at most dealer who carry industrial parts, including ebay.
May 11, 2010 | Juki DDL-8300
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
126 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
