Question about Philips 43P8341 43" Rear Projection Television
Problems with Projection TV shutting off
The TV keeps shutting off. The TV can stay on for as little as two minutes to as long as 2 hours. The TV was purchased in 2002 and I have already had two repairs done on it in the past year with problems with the picture quality. Help!
SOURCE: Turning off and on
same problem here, any help?
Posted on Nov 15, 2007
0 characters
1 Points
TV has good picture sound and picture keep going off up to 2 minutes then returns. Its a sony LCD projection TV 65"
The tv "LAMP" LED light indication staying on or blinking on the front tv bazel frame?The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on and watches like 4 or 5 hours daily?Yes to all of these,mean the tv projection lamp life are ending.Require a new projection lamp for the tv.
Jan 14, 2011 | Sony Projection Televisions
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Tv stays on for couple of minutes and then shuts off
Hear any grinding or motor noises,pictures flashes or flickers in black and white?All these cause are the death of a colors wheel.Must replaced the colors wheel.When was the last time,this tv replaced it projection lamp?1 1/2 or 2 years the projection lamp was replaced,tv on and in used like 4 or 5 hours a day.The projection lamp life is over.Require a new projection lamp.
Aug 16, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
if you know anything about the tv, take off the back and remove the power supply board. Reflow or resolder the solder points, takes like 2 hours, but is well worth it as my tv works fine now. make sure to use rosin core solder and good luck
Sep 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Do you see any deteriation of picture quality before shut down ? This could be a number of diff problems. Need more info
Mar 16, 2008 | Samsung PCL545R 54" Rear Projection...
VS-60111 turns off on its own after few hours
Did you repair the two leads? Ao check near the Convergence ICs for an open resistor or two, although that shouldn't effect your audio. Yu most likely have a low voltage regulator or bad capacitor. You will probably need the service manual to actually track it down. I will post a link where you can ge one for 12.99 and the include free unlimited support. They will also email it instantly to you if you return to the site and send them an email requesting they email it to you. You sound like you could fx it with the service manual and some guidance. Here is the link.
Jan 25, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Samsung HLP6163wx
when is the last time you changed the lamp ?  are the fans clean
Oct 15, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Sony grand wega kdf42a10
Just repaired one of these for this exact problem... Lamp is most likely defective, which is a Xl2100u lamp Sony p/n# A1606034b about $175.00
Jun 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Philips 43P8341 43" Rear Projection Television Logo
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
