Sharp Linytron 13" Remote Problem
I got a Sharp Linytron 13" television with no instructions. Tv model number 13SB50 Remote number G0549CESA The remote doesn't have a menu button but does have a memory button and add button and an erase button. I can't get channels above 36.
When the red dot by the red LCD channel display on the TV is lit (by toggling the memory button on the remote) the channel up and down buttons work as expected but skip channels from 37 to 94 both ways. And random access works on all channels but 37 to 94. If you push in a channel from 37 to 94 the tv just stays on whatever channel you are currently on.
When the red dot is not lit the channel up and down buttons cycle between channel 4 and 36 only. And random access doesn't work, it just returns you to the channel you are currently on.
I have tried the STD, HRC, and IRC slide switch on the back but can' see any difference. My cable provider is WOW out of Columbus OH.
I haven't had any success playing with the memory, add, and erase buttons. Does this model just not get those channels or is there something obvious that I am missing about adding channels? Any help would be greatly appreciated, football is on and I can't see it. Thanks.
  • 2 more comments
  • Anonymous Dec 04, 2008
    I have the same problem using a universal remote.
  • Anonymous Dec 18, 2008
    I also have the same problem and would love to see a solution.
  • mapt Jan 10, 2009
    I have a very similar problem with a Nexus LCD. We have programmed several remotes and the channel up/down key will work for a few days. Suddenly, it will stop working. When you check the menu for channel memory, all memory has been cleared. The only way you can access channels is by using the numeric key pad. HELP!
  • fterry1 Feb 24, 2009
    Same problem as above. Can not get any channels between 36 and 95. Have a universal remote. Please help.
  • 1779 Answers
SOURCE: MAGNAVOX TV MODEL CCT192AT01 FROM DECEMBER/1995
You need the original remote for that. Try "remote controls.com" and I believe they should have one. If not, let me know.
Posted on Feb 26, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
  • 34 Answers
SOURCE: My Olevia TV will not change channels using the remote or buttons
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Posted on Apr 09, 2009
  • 6 Answers
SOURCE: Can not access setup
hit vol down on the tv and hold then with your universal remote puse 1. This will set the tv back to factory defaults and give u acess to all cable channels.
Posted on Jul 30, 2009
sams_trix
  • 93 Answers
SOURCE: what is the difference between HRC, IRC, Std and
Usually standard broadcast is is the default setting,some other cable company use HRC and URC, these are ways to transmit or deliver their signal trough cable wire,ask comcast cable for their transmission type.
Posted on Aug 30, 2009
Control codes for a sharp model 13sb50 for my universal remote
2039 2094 2068 2033
Try these codes. If you wish to get more, visit the sites linked here. Setup code list and proceedings of many brand remote controls are given.
http://electrohelponline.blogspot.com/
http://remotesearch.blogpot.com/
Jan 16, 2017 | Sharp Televison & Video
3-digit code - Help?
What is the model number for the TV?
Also, make/model for universal remote?
Jan 13, 2008 | Televison & Video
Can i use a universal remote to control a sharp model 13sb50
Yes, you can. Search the site linked here, and find out the brand name of the remote control, which have setup code/s for Sharp brand TVs, and buy that remote control. You have to set the remote controls, using the set up code. The procedure too is given.
http://remotesearch.blogsot.com/
I have an older Sharp Linytron TV Model # 19C-M100R. I am looking for a manuel on it to look for a code to program the remote.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 06, 2011 | Sharp 21" Multi System Stereo TV
Need tv code
try the sony codes! let me know if it works.. thanks
Apr 19, 2010 | Jensen JR500 Remote Control
No channel control knob on Sharp Linytron: 1993-Model 1 3SB50.
This set was a massively stupid idea and requires the remote control for everything. You'll need to buy a universal remote control, which should give you the basic functions (power, volume and channel control), but might not get you access to picture or sound adjustments. I don't think this set had any special features.
Mar 26, 2010 | Televison & Video
Sharp linytron with channel problems
tiptop tuner will have the tuner cheap-google them then give them a call to order it
Sep 07, 2009 | Televison & Video
Televison & Video Logo
745 people viewed this question
Top Televison & Video Experts
