Question about Compaq Presario R3000 Notebook
Where is wireless connection switch on Compaq Presario R3000?
Trying to connect wireless. States no wireless networks found (while I'm sitting in the middle of Starbucks) and to make sure the wireless switch is on.
Where is the switch and how do I know if it is on?
    Problem Solver:
  • 4 Answers
Well if u have the same exact one as myself.
The wireless button is on the front right near the corner. above it and on the corner is the wireless symbol. If its working it should be lit blue. push it and see if it lights up blue for a few seconds. You should get a wireless connection confirmation on the screen.
hope this helps you
Posted on Nov 17, 2008
Presario r3000 when i click on bluetooth icon it just says no devices found what can i check
If you are not able to connect or configure the Bluetooth then please check the steps and the link below which will help you to connect it properly.
  1. Click Start , click Control Panel .
  2. Click Switch to Classic View and click Bluetooth Configuration .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00583172&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#c00583172_M4
If any issue persist, please get back with product no. which is at the bottom sticker.
May 31, 2010 | Compaq Presario R3000 Notebook
How do I start the wireless network?
n the right bottom corner you would find an icon for WiFi network. Right click on it and select "Connect to a Network". If that doen Not work then select "Diagnose and Repair". You can do the same thing from Start->Connect to. Here select the Wireless LAN. And do as before.
May 08, 2010 | Compaq Presario R3000 Notebook
Wireless internet on compaq presario 6425 tu
Do you know for sure there is a wireless connection in the area you trying to connect, Wireless internet isn't accessible every were and when it is available it could be protected by a security pass phrase. The only way to really get full use out of your wireless internet is to go to a company that sells the wireless internet cards
Jun 17, 2009 | Compaq Presario Notebook
Compaq presario c300
If you're running a wireless network, make sure all computers on the network use the same network name, for instance "My network" Home Network etc. one can't say "MS HOME" and the computer you're using say "My Network"
Mar 13, 2009 | Compaq Presario R3000 Notebook
How to enable WI-FI function on Compaq Presario 2500 lap top.
Go to "network connections"
It should say Local Area Network and Wireless network (if your card is installed properly). Right click the Wireless Network and make sure it is enabled. Then click "View Available Wireless Networks" and choose your network.
If you are trying to setup a secure wireless network, that may be a completely different issue.
Jan 27, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq presario wireless button no longer working
There is a mechanical problem with the R3000 wireless button and volume-down button where they seem to push fine but are in fact failing to make electrical contact. I know of two work-arounds.
* Try pushing the button with a capped pen, gently at first, and then with increasing pressure. (Not so hard you break the plastic, please!) I suspect this gives the buttons just enough extra "oomph" that contact is established.
OR
* Push up on the battery compartment while pressing the buttons. If the battery is in, you can acheive this same effect by putting your laptop on a table and popping up the screen, then applying downwards pressure on that corner of the laptop body while pushing the button. I suspect this aligns things properly so that the button is able to depress just a hair further.
You may even find that these actions "loosen things up" enough to cause the buttons to work like new for a little while. I hope this works for anyone reading this!
Oct 03, 2008 | Compaq Presario R3000 Notebook
No wireless connection with laptop Presario R3000 (anymore!)
If your volume buttons don't work either this should help. Place your laptop on a table and press down on the lower right of the computer(under the arrows near the microphone and headphone symbol) or clamp down on the battery compartment (center). The blue light on the corner should illuminate, if it's off press the network button while putting pressure(the indented one on the right front edge) you shoud hear a double ping sound. I put a thick felt pad between the battery and the computer andnow everthing works. I know it sounds really STUPID but it works.
GOOD LUCK
Richard.
Apr 15, 2008 | Compaq Presario R3000 Notebook
Wireless radio adapter
if ur sure that that it is the fn and f2 that u have to press simultaneously to turn on wireless capabilty. Make sure u press it long enough
Right click on wireless network connection item in ur system bar and goto view available wireless connection and check what message is displayed there
If it still says that " No wireless network were found , make sure wireless switch is on "
Contact COMPAQ
If ur not sure whether it FN F2 , then try to FN & F5 or FN & F2
Feb 19, 2008 | 2wire (1000-000057-000) Modem
Compaq Presario R3000 Notebook Logo
722 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
