Question about Proscan PS60690 60" Rear Projection Television
PROSCAN PS35682 CTC170RA SHUTS OFF
PROSCAN 80 SERIES PS35682 CTC170RA I TURN IT ON AND THE SCREEN LIGHTS UP BLUE THEN THE PICTURE CLOSES TOGETHER AND SHUTS OFF. THEN YOU HAVE TO UNPLUG IT BEFORE YOU HAVE ANY POWER GOING TO THE POWER BUTTON. IT TAKES IT A WHILE TO HAVE POWER AGAIN.
  • 12 Answers
SOURCE: Proscan 26LA30Q-screen will not turn on
This might help you
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Posted on Apr 04, 2008
caroldon
  • 17130 Answers
SOURCE: Our Proscan 42 inch LED
Possible fault in the convergence circuit, failure of the IC. I advice that you must not tamper on the TV but ask for the warranty replacement without even opening the set. You are entitled to this service and must not throw it off. So call up the dealership and register your complaint .
Posted on Sep 01, 2010
gopakumarg43
  • 74831 Answers
SOURCE: i have a 26lb30h proscan 26
Hello
There are two possibilites for this fault. The first one is shorted inverter transformer in the backlight inverter board. The second one is the fault with main board. For both faults, card base replacement is only possible. Check out which board has the short, and replace it.Image of the digital board is given here. Baclight inverter board can be located aty the panel itself, will be fitted vertically at the right or left side of it.2_8_2012_5_34_32_pm.jpg
Posted on Feb 08, 2012
spr1949
  • 1182 Answers
SOURCE: proscan 40lc45s won't stay on
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Posted on Aug 01, 2012
newfie_todd
SOURCE: Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Posted on Apr 27, 2014
ProScan 32" LCD TV/DVD Combo PLCDV3213A
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size./
Aug 23, 2017 | Proscan Televison & Video
Proscan tv pled1526a powers on but shuts off after blue proscan screen
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 23, 2016 | Proscan Televison & Video
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Proscan tv powers on but no picture
Does the audio still work normally? If so uits most likely the inverter board which has failed and you can get a replacement inverter from www.tvcircuitboards.com
Jan 01, 2013 | Proscan 32LA30Q Television
Proscan 40lc45s won't stay on
Aug 01, 2012 | Proscan 40LC45S 40 in. LCD TV
No screen proscan 42la30h
Lcd/Backlight! Main Problem On the led,lcd is the Bad lcd ribbon or Bord, Try turning off all the lights and Turning it on, then kneel down to the ground and see if u can see Channels changing when u click up/dwn or volume or even the Fuzzy look when theres no cable going to it. if u can see then its probably a bad board or chip.
Hope This Helps :)
Mar 08, 2012 | Proscan 42LA30H 42 in. LCD Television
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
I JUST GOT HOME AN TRIED TO TURN MY JVC PLASMA TV ON. THE TV WILL NOT TURN ON. EVERYTHING ELSE HAS POWER TO INCLUDE THE TV BUT THERE IS NO PICTURE OR SOUND. BLANK SCREEN. THE BLUE POWER LIGHT IS FLASHING ON AND OFF. THE MODEL NUMBER LT-42P789
Jul 16, 2009 | Proscan 19LA25Q 19 in. LCD Television
ProScan Projection TV PS60690 shuts off
It won't turn back on now? Any clicking, indicator lights, etc?....accordianman
Feb 15, 2008 | Proscan PS60690 60" Rear Projection...
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
