Question about Akai PT5492S 54" Rear Projection Television
My tv has a lot of red color in the picture
When trying to watch tv the picture is real red but you can still see all the picture but it is really red
  • dosswz Dec 26, 2008
    T V has a lot of red but blues look green picture is not as sharp as it used to be. Red convergence are red , blue converence are green and cannot adjust out green.
My Tv has no sound, only makes a buzzing noise that gets louder and louder. How can I fix this?
Posted on Dec 08, 2008
  • 153 Answers
Tt might be the problem with he color circuit board, bring it to the repair shop for repair, or if you can do it do re-soldering to any visual crack at the soldered lead terminal of the components on the circuit board and then try put on to check if the problem goes away?
Posted on Nov 10, 2008
Red doesn't seem to be working properly, but doesn't appear to be a bad projector.
The red CRT tube is failing. They are rated at 3000 hrs of operation. Check the red CRT face to see if there is a lot of dirt on it or has a discoloration on the inside of the coolant chamber. These tubes are scarce and expensive. You may want to consider a new TV.
Apr 27, 2017 | Hitachi 46W500 46 in. TV/DVD Combo
I have a 55" rear
U tries go into the tv colors setup and turn down the color RED,might help?Tv could have a problems known a convergence problems,it dead very common problems for old DLP tvs.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resitors too.For fixing the convergence board to solved convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Hitachi Televison & Video
What are the menu settings supposed to be at for the color, picture, what do I do if the color is not right, pickish and green
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Feb 05, 2011 | Panasonic CT-32G23 32" TV
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
I have to much red in my picture
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant red picture tube, a bad red driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. This TV set most likely will run you about 200 to 400 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
TV turns on, but picture is red/black
you can try the main board and the control board first (this is the lesser of two evils), if that doesn't do it, it's definitely your sustainer board is bad.
Jan 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
HL-P5663W
Well after reading a lot more on the internet I figured out that there is a jumper that has to be removed when you update to the new style color wheel. Also when you get the new wheel there is a new set of color setting that needs to be programed into the tv itself. NOW the picture is AWESOME! better than when it was new.
Jerry
May 15, 2008 | Samsung DLP HL-P5663W 56" TV
Bad Color - Not much red
picture tube is goin bad............
Dec 28, 2007 | Sony KV-32S26 32" TV
Akai PT5492S 54" Rear Projection Television Logo
78 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
