Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
No water coming out
Making a grinding sound with no water coming out
    Sergeant:
    Champion:
  • 324 Answers
Something stuck in your pump? you may be able to get to it from the inside of the tub.remove the screen and check under it.
Posted on Nov 11, 2008
My cabrio top loader high efficiency low water washer is making noises
sounds like water has got past the seals and into the upper bearing.if this is the case you will hear a loud roaring noise during the spin cycle.not a cheap fix!
Dec 17, 2017 | Whirlpool Washing Machines
My engine is making a gurgling grinding sound near
Is the coolant system completely full? It may have air in the system and what you are hearing is the air trying to pass the water pump.
You could also be hearing the valves and air flow through throttle body.
Nov 23, 2009 | 1991 Geo Storm
Grinding noise from passenger side engine
The water pump bearings could be going out and they will make a grinding noise.The water pump doesn't always leak when the bearings are going out.
Sep 01, 2009 | 2002 Dodge Neon
Grinding sound SA8605x
Sounds like machine may have activated flood switch- this makes the dishwasher drain continously, which results in a grinding noise once the machine has no more water to pump out.
The flood switch is located in the base of machine- you need to remove bottom front panel to acces (disconnect from power first!!).
Once panel is removed, check:
-Is there water in the base? If so, machine has had a leak- clear water, restart, and locate + repair leak.
-If no water in base, it may have air lock in pressure tube. There is a small clear tube that goes to round flood switch on base of machine- remove tube and blow thru. Reassemble and test machine.
Only attempt if you a confident DIYer- if in doubt, call an expert (you can sometimes make an easy repair an expensive one)
Aug 10, 2009 | Smeg CSU2001 Built-in Dishwasher
Machine making loud grinding sound. got belt thighten and it did about 4 loads and the noise has returned
The Water Pump has a shiney metal retainer that can come partially out and grind into the housing causing the pully to slow and stop.
Aug 08, 2009 | Maytag HAV3460AWW Top Load Washer
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
Will not spin and making grinding noise
a grinding noise sound i think it come from ballbearing you can chang by qualified person
Apr 17, 2009 | Whirlpool LSN1000LW Top Load Washer
Load grinding noise, like the engine is working too hard.
Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Washing machine
THAT GRINDING SOUND is coming from the main motor , first you have to check a CAPACITOR located near the motor , disconnect it and try START AGAIN , IF it still giving you the grinding sound check if its coming from the motor , if so youre gonna need to replace it , cause the motor come from the factory SEALED ,making it imposible for repair,hope this helps AJ
May 06, 2008 | Kenmore 22422 Top Load Washer
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
164 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
