Question about Ducane 30400042 (LP)
Gas burners heat unevenly
Burners are hotter in back of grill instead of heating evenly throughout the entire surface
  • Anonymous Jan 27, 2009
    Back of burners ignite and stay on but fronts do not ignite unless control knob is pushed in but then go out when control knob is released.
  • Rferg Jan 27, 2009
    Backs of burners ignite and stay on but fronts do not ignite unless control knob is pushed in but then go out as soon as control knob is released.
  • 9 Answers
I had a similar problem. I took off the burner heat deflectors and seen gaping holes in the burner tubes. Get your model number and serial number and call Weber. Most Ducane grills have a 5 year warranty on the burner tubes. They will ship them free if under warranty!
Posted on Jun 26, 2009
Just bought a Weber Genesis II LX Model S-340 Natural Gas Grill. The plumber installed a 54' line, 1" in diameter. The grill will only heat up,to 400 degrees. What could be wrong?.
If he really installed a 54 foot line instead of a 54 inch line, the line is way to lone. The gas pressure isn't high enough to supply enough gas to the grill to get any hotter.
Oct 19, 2017 | Weber Grilling
Why southbend temp various over the grill ? set on same settings but will be hotter in spots
This uneven heating is something "grillers" have dealt with since we started cooking...the heat is higher directly over the source and gets progressively cooler as you move away.. This is more pronounced with gas or electric grill/cookers..because the heat source is in a fixed position...WITH charcoal, you can spread the coals out (if you use enough).. and get even heat over a larger area.... I have a NEW 4 burner(w/hot pad) Charbroil gas grill and a old Charbroil charcoal grill...I HAVE NEVER used the gas grill...and I grill 1-2 times a week!! ..(it was a gift/two years ago.... wanna buy it?)
May 31, 2017 | Grilling
Are lava rocks used with charbroil 463731703? Can they be used with this bbq?
Since your grill uses a V - bar flame tamer over the burner, I wouldn't recommend using Lava Rocks. As there is no grate to set them on above the burner. Putting them directly over the V-bar flame tamer, won't allow the burner to heat evenly and you'll have hot and cold spots throughout the cooking surface.
Hope this answers you question.
Apr 23, 2011 | Char-Broil QuickSet 463731703 (LP) Grill
Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Dec 20, 2009 | Weber Genesis Silver B Grill
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Ducane stainless steel NG BBQ with uneven heat front to back
all grills are hotter in the back than the front even if you bought a grill that was 6000.00 it will do the same thing
Jul 26, 2009 | Ducane Affinity 3100
Turbo BBQ burns hotter at end
there is a larger groove in the rear of the burner to make it hotter in the back for searing. This is by design.
Mar 10, 2009 | Grilling
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Stove
Electric or gas? Is it clean and not lined with foil? If gas, does the flame all look blue along the burner length? If electric, how many elements are there? Do they all glow in the area where you expect them to when the unit is heating? Where are they? Answering these questions should lead to a solution.
Dec 07, 2007 | Ovens
Ducane 30400042 (LP) Logo
763 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
