Question about Philips Standard 104SLE 14 in. CRT Monitor
LED remains OFF
While using my Philips 104S color monitor I heard a sharp sound like a small gunshot. After wards when I rebooted my computer, even though the fuse of the monitor is okay, it wasnt powering on. The on/off LED also seems to be OFF even though the power cable is okay. I suspect a high voltage circuit is shot but How do I check that and What should I do? I opened the cover and lot of dust seems to have settled in. After cleaning also it didn't turn On.
Please out power amplipier section. Power driver Transistor may have been destroyed. Also chekc rectifier diodes.
Tell me if your problem has been solved.
Good luck
shadab_a4u@yahoo.com
Posted on Nov 27, 2007
SOURCE:
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
My screen size is reduced not any problem but when i use the keys on monitor they instead of widing or giving the normal screen size it became 1 inch shorter now i need some help with my moniter it looks...
Try holding the control button down on your keyboard and while holding it down, use the scroll wheel on your mouse and rotate it slowly one way or the other. This will increase the size of your screen (or decrease it depending on which way you turn the wheel).
Jan 29, 2018 | Philips Standard 104S 14" cRT Monitor
Philips Brilliance 200w6cs Backlight off Green LED ONN
Check to see at one of the pin on the inverter board has 12vdc feeding it. No bad capacitors? Pictures?
Nov 29, 2009 | Philips Brilliance 200WP7ES - Flat panel...
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Monitor keeps blank even the power lLED is on green
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Philips 104 series monitor
pls help my philiphs monitor 105s vertical probelum i need service manuval pls help
Feb 14, 2008 | Philips Standard 104S 14" cRT Monitor
Ic
TDA 4841 IC IS USED FOR horizontal and vertical scaning IF YOU WANT its ckt you can get it from www.serviceinfo.com good luck
Sep 18, 2007 | Philips Standard 104S 14" cRT Monitor
104s philips monitor
Why do you suspect the horizontal or vert curcuits? I would suspect the HV curcuit since no display at all. Gary(Honkity Hank)
Sep 18, 2007 | Philips Standard 104SLE 14 in. CRT Monitor
Pin assignment for 104S monitor cable
you will get right pin alignment& complete ckt from web site IF YOU WANT its ckt you can get it from www.serviceinfo.com good luck
Feb 14, 2007 | Philips Standard 104S 14" cRT Monitor
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
Computers & Internet Logo
51 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
