Question about Whirlpool Refrigerators
Whirlpool refrigerator model ET8CHMXKT06 rear wheel replacement
Rear wheel broke.
Can't see how to replace it.
  • 5 more comments
  • gcjones2 Nov 10, 2008
    I can get at the wheel axle, just can't see how to remove it to put a new wheel on.
    I have unplugged the unit and will not be touching electrical contacts.
    The roller is not accessible from within the refrigerator. Why woul I remove all of the trays?
    Great.
    If that is true, I suppose I should learn to move it on three wheels.
    Thanks for trying.
    Would this solution mean that I need to lay the unit down on its side to work on the bottom?
    I can do that, but wouldn't want to if the likelihood of success is low.
    Any guess on the chance that the axle assembly is riveted rather than bolted?
    OK, Irish Druid.
    I think that I will tip it, and try to find the fittings.
    If it is bolt or screw, I will lay it on down and replace both wheels.
    For some odd reason the replacement wheels are solid hard rubber, but it originally came with flimsy hollow plastic casters, one of which broke in half the first time I rolled the unti out to clean behind it.
    The cause of the break was apparently the stress of rolling over the 1/16" seam between floor tiles.
    Give me a break - Whirlpool should be ashamed.
    Thank you for your patience and I will update you so the answer to this question can go on file.
    Sorry, but I don't see the rear rollers on any of these diagrams.
    Although no Whirlpool diagram that I could find showed this, the rear wheel axle can be removed as follows.
    1. Remove the small hex head sheet metal screws that hold the cardboard dust cover in place.
    2. Remove the 1/2" heavy hex head screw that holds the cabinet to the base at the bottom rear corner.
    3. Tilt the entire unit over at 45 degrees propped up by a large soft sofa or chair.
    4. Using a large flat blade screwdriver, gently pry the base away from the cabinet about an inch. This will allow removal of the wheel axle and replacement of the crappy plastic caster with the higher quality hard rubber replacement wheel.
    5. Reassemble and replace the opposite side crappy plastic caster since it is bound to break sooner or later.
    Brigadier General:
  • 6,966 Answers
To my understanding, the wheel (roller) is riveted to the bracket, but the bracket is screwed to the body.
The exploded diagram maybe of further information as well as the parts list.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
  • Louie  Role
    Louie Role Nov 10, 2008
    The link to the exploded diagram does not work, pls try here.
  • Louie  Role
    and final try to link here.
    Sergeant:
    Novelist:
  • 196 Answers
Locate and remove the 2 screws that secure the console to the cabinet (usually located in the rear corners). Tilt the console backwards. Remove the 2 gold clips, and disconnect the lid switch wiring harness. Tilt the entire cabinet forward, and off of the base. The lid switch can now be accessed, from inside the cabinet
    Genius:
  • 2,035 Answers
You can change the assembly its bolted to unit, please click here and get the part number and part diagram ...
Good luck....
  • Anand Kumar
    Anand Kumar Nov 10, 2008
    Wheel assembly is similarly to front wheel assembly just lay down and replace the wheel....
    Good luck...
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to removed all food inside of
refrigerator then remove all the tray
and now replaced the wheel
    President:
  • 2,712 Answers
You may have to undo the back / lower panel. However, i wouldnt recommend playing with the fridge as there are large currents involved. Best left to a repairman.
  • 4 more comments
  • Swilin Sampson
    Swilin Sampson Nov 10, 2008
    You may have to change the whole wheel assembly, meaning from where it is bolted down or riveted..
  • Swilin Sampson
    Well, you could lean the fridge against a wall to access the wheel
    area. (Make sure you remove everything from the fridge first! )
    Look at the screw/bolt heads..If you find the regular hexagonal bolt,
    or a screw groove, then it is not riveted. If you see it is just a flat
    head, then it is. (I am talking about where the wheel holders attach to the bottom of the fridge,, and not the wheel itself).
    Usually these are not riveted in, to allow for replacements, but it is difficult to say without actually inspecting it. Once you take a look, you will know exactly what's to be done :)
  • Swilin Sampson
    @mmechanics: WHAT ARE YOU TALKING ABOUT A LID SWITCH???? THIS IS ABOUT THE WHEEL!!!!
  • Swilin Sampson
    No problem, please do take a look at Benimur's solution as well. That may be of help.
    And yes, having plastic hollow coasters instead of a solid wheel on a heavy appliance like a fridge IS a bad idea..well..
  • Swilin Sampson
    Hmm..seems to be that Benimur's links to the pics are not working..
    In any case, you will have to replace the whole wheel assembly (including the brackets) and not just the wheel itself.
  • Swilin Sampson
    I told you you'd be able to figure it out once you took a look :) And thank you for posting the procedure here. I am sure others would also be able to benefit from it.
    Cheers!
    ID
Rear wheel adjustment refrigerator
Don,
Most refrigerators do not have wheels that can be adjusted in the rear. The only adjustable ones are the two up front.
Jun 10, 2015 | Whirlpool Refrigerators
Refrigerator and freezer get cold but freezer does not freeze whirlpool 1997 model et22dkxfn00
Can you remove the rear panel in the back of your freezer and tell me what the frost pattern looks like? When a refrigerator loses Freon the frost pattern looks like this photo HERE If the rear wall of your freezer looks like this you still are having a defrost problem photo HERE
Here is what that will look like behind the rear panel of the freezer should the defrost heater and defrost thermostat need replaced HERE
You mentioned that you have already replaced the defrost timer so we should not be concerned about that. The defrost heater=> 2315530 Defrost Heater
The defrost thermostat=> 4387503 Defrost Thermostat
I will be here should you have questions or comments, Thanks Sea Breeze
Mar 04, 2013 | Whirlpool Refrigerators
My real left wheel moves back and fouth while the car in park. it make noise when drivin look like a bar is broke
This is very unsafe do not drive until you replace this. This bar locates the rear wheel and if it is broke you have a good probability of the wheel coming off. This part is called a trialing arm if it is what is connected from the rear suspension to the undercairage in front of the rear end. Hope this was helpful and good luck.
Aug 08, 2011 | 1997 Chevrolet Lumina
Hi, I own Toyota Emina Estima TD permanent
There may be more to it.. Transmission- P.T.O(Front wheels)-Rear Differential(Rear wheels). Or may have Transmission-Transfercase drives front differential(Front wheels) and rear differential(Rear wheels). So if one was rebuilt there should still be another that is still the root of the problem. Find out what exactly was rebuilt.
Apr 19, 2010 | 1996 Toyota Previa
The truck shakes in the rear at 55 to 65 mph...Had repair work done after a collision behind the cab broke the driver's side rear leaf spring...The spring was replaced and had 4 wheel alignment done, new...
well i bet the tyers are all out of ballance,,,check that first if there all ok have a look at the drive shafts and the prop shaft one may be bent?
Nov 18, 2009 | Refrigerators
Whirlpool refrigerator - condensation, ?clogged drain
The stopped up drain tube is inside the freezer probably behind the rear wall. There should be screws in it to remove it. Remove any ice at the bottome and you should be able to see it. I don't know about the wheel.
Aug 14, 2009 | Refrigerators
Broken amana refrigerator wheels
Usually the roller for the rear of the fridge has an axle that is just a pin that will slide out(need a model # to know for sure) and the weight of the fridge holds the pin in place.
Dec 05, 2007 | Refrigerators
Refrigerators Logo
163 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
