Question about Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor
Planar FVT1503Z or Model 03761428 17" Flat Panel LCD. Power light on but no raster on screen
Planar FVT1503Z or Model 03761428 17" Flat Panel LCD. Power light on but no raster on screen. Raster flashes momentarily when power off then power on.
Benimur
  • 6966 Answers
SOURCE: NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
Fix-4U
  • 293 Answers
SOURCE: PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Posted on Dec 27, 2008
  • 732 Answers
SOURCE: Monitor setting panel on permenantly
mrjk65, If monitor still has bright, crisp images displayed on the LCD panel your monitor could be worth saving! Unplug unit from wall outlet and plug it back in! If same problem occurs then most likely problem could be a DC voltage is slightly "out of spec" or a settings panel push switch may have failed. My guess is that when STRANGE out of the BLUE things start to happen for no reason, I would suspect the "switch-mode-power-supply" to be the item at FAULT. Visit YOUTUBE for vids of "LCD monitor disassembly" , "LCD monitor repair" . You will be glad you did. Also try www.ccl-la.com/badcaps.htm , www.lcdparts.net , www.badcaps.net for more info. hope this helps. Bye for now. 12fixlouie.
Posted on Nov 08, 2009
  • 44 Answers
SOURCE: on Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Posted on Jul 30, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Planar 1910(Black)
It has white screen becuase it may not be getting the 5vdc from the logic board to the T-CON board or the board has blown fuse.
Please see http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Also look to see if power supply/logic bd had any bad caps also.
Posted on Aug 15, 2010
Testimonial: "Thanks! It was the TCON that was the problem. I had to reconnect it, it was not inserted all the way in."
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
The touch screen does not work
here is the user's guide for your touch-screen monitor :
(from Planar's website)
http://www.planar.com/media/87916/mn-planar-pt1700-01-m-mu.pdf
Feb 26, 2014 | Planar PT1700M 17 in. Flat Panel LCD...
Power light is on but no picture
you did not mentioned if you have raster or none, if your tv has raster but no picture your problem is in your I.F. section and your tuner, now if no raster, you can check your power supply, check your 5volts, 9volts, and 12volts check any alternatives that cause of no picture..
Sep 09, 2013 | Toshiba 40RV525U 40 in. LCD TV
I have Samsung LA32C400 LCD TV. Recently, some vertical lines appear on the screen, then colour changes, and sometimes the pictures doesn't move.
i have tv samsung model samsung lcd tv model la32c400...when you open the power on. they have a raster but it is hung .up...and then we open again the power booton on pwer it is have only light display ...and also based side have small line ruster only 3cm....what cause this and problem the t-conn....has fixed already in lcd or disposable .....what is the solution on this parblem......some help.....plssss txt me 09991375154 thank u.....
Jun 12, 2012 | Samsung LE Televison & Video
On Planar PL1700 monitor, screen stays black after power failure
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
Hi...there
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Green Light on no picture
More than likely, the planar LCD sets have a set of 5 1000uf 16volt caps that fail. There could be other problems, but to check, unplug, pop off the cover, and look at the brown cannisters. They will mostl likely be bulging, or you may see blackish goo coming out of them. They're fairly easy to replace if you have experience with a soldering iron.
Oct 17, 2007 | Planar XP17W 17 in. LCD Television
Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor Logo
585 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Joe Goldman
Joe Goldman
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
