Question about Whirlpool LEQ9858P Electric Dryer
Dryer has water in the vent
My dryer has had water in the vent where the lint is suppose to go? Is is clogged or what.? What should I do.?
  • Anonymous Mar 13, 2008
    I think my dryer may have the same problem being that it wet behind it?
    President:
  • 878 Answers
Connie, either your vent hose or the vent leading outside your home is severly clogged. This is the only way you will get water in your vent hose. If you are vented to the roof, have someone check the screen up there. Catriver...post back
Posted on Oct 28, 2006
Water coming out of back of dryer
Is either an issue with your ignition, gas system or vents. Unplug it. Are your vents clogged with lint? Lint fires are always a threat, if you find a lot of lint have it cleaned professionally.
Jan 13, 2015 | Maytag Dryers
Maytag model #: med5770tq0 won't dry. Please help
Dear Emily.
Several problems.
First, did this dryer ever work properly hooked up as it is?
I mean hooked to the roof event?
If it used to work just fine, then I suspect the vent to the roof is clogged with lint and is not allowing the heat to escape.
If it never did work right,(for example: it is new to us) then I'd venture dryers are not supposed to vent their hot air that far away, they do not have a strong enough blower to push that air that distance.
Then, you might try to find another place to vent the hot air, with a total distance of only 10 feet from the dryer, even if you only vented it while you were actually drying clothers.
I doubt if the last item is for you, but I have sometimes seen where the washing machine did not spin all the water out of the clothes, and then the dryer needed all day to get the clothes dry.
Be blessed.
Apr 17, 2013 | Maytag Dryers
The dryer is getting the clothes hot, but not drying. What causes this problem? Thanks
venting issue, you can disconnect vent tube and run a load of clothes if it dries then it is the vent tube, if not then the dryer will need disassembled and all the lint clean out from the lint trap to the end of the dryers vent tube, if is recommended to clean the lint out of the inside of the dryer at least once a year, varying on usage, and the lint screen each time before/after use. Hope this helps Tim
May 22, 2011 | Dryers
Hi Our Bosch dishwasher (sms63e09uk) has E:01 displayed on the digital control panel. What does this mean and how do we rectifiy the problem
It means the machine is not getting enough water you need to replace the water inlet valve, that is very possible try cleaning it and see if that helps.If it does not then the problem is the water valve.Which is a very common problem.
This air flow error code refers to the dryer vent. This can refer to the dryer's lint screen, the thermistor behind the filter, or the vent itself could be clogged.
In order to determine which one is the problem we will need to gather some information.
1. Will water pour through lint filter's mess?
2. Outside where the unit vents on the side of the house can you feel air coming out?
3. Is the vent hose on the backside kinked or clogged?
4. Obstruction on vent housing outside (if screen is present on outside remove right away this is a fire hazard.)
Water should pour through the lint filter easily. Fabric sheets will put a layer of wax on the lint screen causing the dryer air circulation to be cut off. We should be able to feel warm, moist air at the vent outside. If air is not present you are in need of a dryer vent cleaning. A kinked or clogged vent hose can also cause the E01 error code. Ensure the vent hose is clear and placed in position with as few bends as necessary. When the vent is clear the E01 error should clear itself upon start up.
Hope helps.
Apr 02, 2011 | Bosch Dishwashers
My dryer runs for several minutes, then starts beeping and an error code E: 01 is displayed. I've tried unplugging it for 30 minutes, but that was no help. Any ideas?
This means that the dryer is not able to exhaust correctly. Often times this is caused by kinked or blocked vent behind the dryer. If that looks ok, the vent in the wall may need to be cleaned. In this case or in most a professional dryer vent cleaner would be needed to clean the dryer vent.
One last thing you can check is the lint screen. On Bosch dryers the lint filter will become clogged from the dryer sheets. Remove the lint filter and run water through it. If water runs through, the lint filter is good.
I know this unit well and can assists you with any repair related question you have.
Let me know
Mar 26, 2011 | Bosch Nexxt 500 Dryer
When I open the dryer door, there is water standing in the bottom of the dryer and there is water on the drum. It has a musty smell in the dryer. What is causing this?
The vent hose is clogged , also there may be lint clogged inside the dryer. Disconnect the hose and see if you can feel hot air coming out, if you can then it is in the vent hose. If not then you will have to take the dryer apart and clean all the lint out
Jul 19, 2010 | Maytag Neptune MCE8000AY Electric Dryer
I checked the connection of the dryer and nothing is clogged....the clothes take 3 hours to dry a small load...the dryer feels hot...in addition it appears there isn't that much lint on the lint screen...
check your dryer duct hose and vent.....it might be clogged,.....in some cases the duct fills with water and causes dry time to take longer.....on other cases the vent might be clogged and the heat sensor detects that it is hot enough and shuts down the heater element.................
make sure all vents are unclogged.............
dryer duct hose is in the back of the dryer and is connected usually with a duct clamp or tie strap.........disconnect and if i were you replace with a new one.... do not rinse out and put back....it will cause a build up of lint around the inside of duct hose.....the water acts like a glue trying to collect all the lint it could...and eventually it will clog the hose..............just replace with a new one......check the vent were the hot air discharges out of usually outside or rooftop........most vents are covered with a screen or a plastic/sheetmetal flap.....make sure the flap can move.also make sure that it is uclogged and has good airflow...........................
good luck if anything just message
a feed back would be good if this helps...
Jun 19, 2010 | Kenmore 62802 Electric Dryer
A week ago we bought a Kenmore Model #88042 dryer. Why does not the book that comes with the dryer say that condensation is very prominent, and the lint does not all go into the lint filer, but all over...
If you experience heavy condensation inside the dryer, and have lint accumulating inside the drum, you have a clog somewhere in your exhaust ducting. Since this is a recently purchased (new?) dryer, I'm assuming the clog is EXTERNAL to the dryer.
A quick test that you can try to determine where the problem may be is to remove the exhaust ducting from the back of the dryer and attempt to dry a normal load of wash. If the air flow from the back of the dryer is forceful and warm (about 140 degrees F), and the clothes dry normally, the problem isn't the dryer. The problem is in the ducting from the point where it leaves the dryer to where it exits your home. If this is the case, you will need to inspect the entire length of the ventilation to ensure there are no kinks, clogs, sags, or significant bends that can cause choke points for lint to accumulate. If left in this condition, the dryer will eventually overheat to the point of failure.
If the air is weak and hardly moving at all, you will need to inspect your air blower assembly inside the dryer to ensure the fan is not obstructed and the ducting is not clogged.
If you have any questions, please let me know. I hope this helps you.
Jul 20, 2009 | Dryers
My kenmore Elite Dryer model he3 starts but there is no heat, what is up with that and what can I do to fix it since my warranty is over.
Most dryers stop heating due to a clogged vent or duct. Check your duct hose inside the house for lint/water clogs. You will have to remove it to do this. Then check the outside vent for lint clogs and make sure that its opening properly (louvered vents). If thats not the case, call up Sears and use your warranty.
Jun 05, 2009 | Dryers
Dryer takes too long to dry a load
Have you checked the lint screen? pull the lint screen out and remove the lint then hold flat and pour water on it. Does the screen hold the water or does the water flow through? If it holds water, then you must actually clean the film that has coated the screening material. Use dish soap and scrub lightly then rinse clean. and check again.
Apr 02, 2009 | Kenmore 62872 Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
