Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Water resevoir leaking
Water leaking out of black rubber waser
  • 2 more comments
  • crstrohmeyer Nov 30, 2008
    The reservoir is leaking and does not hold water. Can this part be replaced?
    The last one we had replaced was in 2002 when it did the same thing. But, now they don't make this particular pot any longer.
  • conmac5 Feb 18, 2009
    Stevecarte, can you explain creativity in some more detail? The rubber gasket for the valve I have has a small tear where the rubber goes over the water input fitting.
  • Steve May 08, 2014
    The tear in the rubber gasket is the source of the water leak. Press out the old leaking water valve and press in a canibalized one which does not have a ripped rubber basket. They are available on eBay if you keep you eyes open.
  • 29 Answers
Replacement ODC 325 water reservoirs no longer for sale.
I keep a second ODC 325 machine for canibalization. The black rubber water valve assambly can be repaired (I did it 2 weeks ago) but it takes some creativity.
Posted on Feb 16, 2009
Hi My freelander has got pressure from the water resevoir. I still have heating inside car,gauge stays normal.fans working normal.seems to loose water out of resevoir. had new head gasket, thermostat and...
The cap that holds pressure inside the cooling system -- whether located on the plastic water reservoir or the radiator -- could be bad, even if it looks OK. Buy a cheap replacement online.
Also look for cracks in the rubber overflow line from the radiator to the reservoir -- they often go bad.
If the main water hoses between the engine and radiator haven't been changed, replace them (even if they look good). Many times, when old hoses are removed, they start leaking when they're replaced because the stiff rubber doesn't seal properly -- and your radiator hoses were probably removed when they changed out the water pump.
Also,
--search online forums for your year/model to see if others have same problem.
--if all else fails, drive the car until the engine is good and hot, support the front of the car with jack stands or wheel ramps (NEVER only with a jack), turn on the engine and let it idle. As pressure builds, if there's a leak you should be able to see it dripping. (Don't confuse, though, with condensate dripping from the a/c condenser, which is normal.)
Feb 08, 2018 | Cars & Trucks
Why does my hoover fh40150 leak water from the clean water resevoir?
Hi! The clean water tank may begin to leak if solution is stored in the tank. This can cause the rubber seal on the clean water tank to disintegrate. The tank will need to be replaced. To purchase a replacement clean water tank just follow the link below. Hope this helps!
Solution Tank Assembly Complete with Lid Cap
Aug 11, 2014 | Hoover Floormate Hard Floor Cleaner,...
My screen waser moter not working
First, check the availability of water in the wiper tank. If its OK then check the condition of the rubber tube. Then replace the motor if needed.
Mar 07, 2014 | Maruti Cars & Trucks
How to Fix Overheating in a 1996 Mercury Grand Marquis
If none of the seals to the cooling system are leaking and if it is not throwing a code for the heating or cooling temp sensor, check the coolant resevoirs cap. Under that cap is a rubber seal, if that rubber piece is in any way defective it will not hold any pressure in the resevoir due to it being a closed system. A replacement rubber seal will run you about 7 or 8 dollars at your local auto parts store. I had the same problem in a 96 crown victoria and it took me about a week to track down the problem.
Jul 30, 2012 | 1996 Mercury Grand Marquis
Water leaking from reservoir
I had the same problem. All of a sudden my kitchen top counter got filled with water. The water was leaking from the Nespresso C190 water resevoir at the bottom. Exactly where the reservoir meets the coffee machine base. I had by chance an "O" rubber ring left from a faucet which I inserted at the base of the water rervoir right on the small **** which when it sits on the C190 base lets a valve open in order the water to flow through. The "O" ring was 2 to 3 mm in diameter and about 1 mm thick, You might experiment with different ones until you solve your problem.
Jul 02, 2011 | Nespresso C190 Espresso Machine
Where is the coolant resevoir on a 2002 Kia Sportage
On top of the radiator there is a black rubber pipe that goes into a plastic tank that is for excess water when car is hot and sucks water when it is cold, there is no coolant reservoir. Coolant must be put into the radiator.
Sep 25, 2010 | 2002 Kia Sportage
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
Windshield washer fluid hose is leaking behind front right wheel
I had the same problem. Reservoir would drain for no reason and I later found that the water was soaking the passenger side carpet and filling the wire channel under the doors. Tracked the problem to a barbed fitting behind the passenger side kick panel, just below the dash. The fitting connects the tubing coming through the firewall from the reservoir to the rear wiper/washer. The hose had come loose from the fitting (possibly due to freezing). I re-installed the tubing onto the the fitting and it has been fine ever since.
Feb 15, 2009 | 2001 Ford Expedition
JURA X90 ESPRESSO MACHINE LEAKS UNTO COUNTER
inside the machine a rubber tube is broke or loose causing this leak!
Dec 09, 2008 | Jura Capresso Impressa X90 Espresso...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
714 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Greg Cann
Greg Cann
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
