Question about Brother Sewing Machines
Brother se270d Hi, My sewing machine does not hold a stitch. The bobbin thread on the bottom is constantly getting tangled. The stitching can be pulled out by hand. I don't know what to do to rectify the issue. Thank you for your input! LeeAnn
    Problem Solver:
  • 9 Answers
Tighten the tension on the bobbin thread. or you are using the wrong size bobbin spool.
Posted on Nov 26, 2008
Bottom thread is a tangled mess. Was going great, now can't sew.
bottom thread mess is an indication that the needle thread tension is too loose
check the needle /hook timing to ensure that it hasn't altered
Jun 28, 2015 | Singer 6180 Brilliance 80-Stitch Sewing...
Stitch issues
Find the tensions on your machine. Usually a screw below on the bobbin regulates the top stitches tension. Usually a numbered wheel on top--where the thread is around it--regulates the bottom stitches. YOU NEED TO ADJUST THE TOP WHEEL, test on scrap material, and if looser, you are in the right direction. If it is still a mess. turn the knob to a lower number.
Apr 04, 2014 | Brother CS6000i Computerized Sewing...
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
I have a Brother SE270D and my top thread won't pick up my bobbin thread
Replace the needle with a Schmetz needle. If that doesn't work you need to get it serviced
Feb 21, 2014 | Brother 98-Stitch Computerized Sewing &...
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
I have a Brother CS6000i sewin machine and I'm
Mmmm Are you using the right stitch? Like zig zag or straight stitch only with a medium stitch length? Check that and test again.
Sep 06, 2012 | Sewing Machines
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
When I sew it only sews about 4 stitches the top thread breaks & sometimes the threads are all tangled in the bobin area. I found a small spring next to a larger spring loose. Where does the little...
You may want to take it to be looked at by a professional if there is a part loose.
I have constant problems with thread breaking and being tangled in the bobbin area with this machine. It can usually be remedied by adjusting your tension. Also, class 15 bobbins stink for this machine (yes, it says they're compatable, but they seem to be 1/8 of an inch too shallow and constaly become unthreaded from the bobbin casing). Try SA 156 metal ones.
Aug 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Bobbin tangles on Brother xr 65
This was happening to me too, I reversed the bobbin feeds and it has not tangled since then. I was orignally feeding the bobbin from the left side and now i feed the thread from the right. It works great this way.
May 19, 2008 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
152 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
