Question about HP Officejet 7210 All-In-One InkJet Printer
Black cartridge is not being recognized, amber light blinking
I went to the HP site and tried their solution. Cleaned contacts, turned off, unplugged, reinstalled cartridge, tried a new cartridge, over and over again. Could it be a faulty cartridge?
  • angelajill Nov 10, 2008
    You were right on the money, unfortunately for me:( Thank you for solving the mystery.
    I guess I will try to find a repair center, the printer is 3 years old. I appreciate your help!
  • 345 Answers
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Nov 10, 2008
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
Printer does not see the cartridge
mine did that a year ago try to reseat the cartridge take it completely out and place it back in
Jul 21, 2009 | HP DeskJet 9800 InkJet Printer
BLINKING ORANGE LIGHT AND NO PRINTING
I just experienced this with my 920c. I cleaned the contacts in the cartridge holders with alcohol and the problem went away.
Jan 31, 2009 | HP DeskJet 920c InkJet Printer
Amber light!
Clean the contacts in the cartridge holder (Iso alcohol & cotton swab work well).
Dec 23, 2008 | HP DeskJet 920c InkJet Printer
Nothing will print; blinking amber light
Are you out of ink? when you open the lid to the printer while it is turned on look at were your ink cartridge stops and that will tell you if you are out of colour or black ink. Which light is blinking the one on top of the paper symbol or the one on top of the ink symbol. It may be that your cartridge either black or white just need to be taken out and put back in I found that if I wiped the bottom of the ink cartridge where sometimes you get build up that it would work again or give it a shake but make sure you cover up the bottom were the ink comes out before you shake it. Hope this helps!
Nov 15, 2008 | HP DeskJet 920c InkJet Printer
Remove and check color cartridge [it dosnot work]
i went to the hp website and they acknowledge this problem they have a page on this http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&cc=us&lc=en&dlc=en&product=59273
it appears that there may be dirty contacts in the printer as well, i changed the black cartridge and it started working, just luck i guess
Oct 14, 2008 | Office Equipment & Supplies
Power Light Continues to blink.
if you are having issues after installing the new cartridges , then perform the following steps.
unplug the power adapter and remove both the cartridges and then power on the printer , look for the power light. if it does not blink then .
install the black cartridge first and then try to print , if it prints fine its ok. then remove the black cartridge and then put the color one in and then try printing or copying .
if it doesnot print with any either black/ color then you have to replace that particular caratridge..
lemme know once u r done....
May 02, 2008 | Lexmark X1270 All-In-One InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
541 people viewed this question
Ben Johnson
