Question about RCA F35670MB 35" TV
TV shut off
We were watching our TV last night and it shut itself off and would not turn on with the remote or on the tv itself. I moved the plug to another on the strip and it turned back on. Now this morning it shut itself off again and nothing I do will get it to turn back on..even trying a different strip from a different outlet.
  • Anonymous Mar 30, 2014
    after watching for about 20 mins tv shuts off
    Sergeant:
  • 337 Answers
The set is going into shutdown,there are a few reasons why the circuit is being activated,excessive high voltage,excessive volts supply(poor regulation)no screen voltage or a secondary supply is missing,if you are familiar with tv service you have a few places to check,you will need a volt meter and a soldering iron and the squematic diagram to locate the different circuits mentioned,if you are not too familiar seek the assistance of a servicer.Let Us know if you need more information.
Posted on Oct 27, 2006
  • Omar Urrutia
    Omar Urrutia Oct 27, 2006
    your rating response is also important.
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Watching tv last night, the tv turn off by itself with out touching remote control, after that i keep trying to turn it on and the on/off red tv light startted flashing for a few minutes until it when off...
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Oct 07, 2010 | Samsung LN40A450 LCD TV
First tv kept tuning on in middle of night now its kepts tuning off while ur watching
I don't know what might have been making it turn on in the middle of the night. It it keeps turning off while you are watching, you might want to check if:
1) someone is accidentially hitting the SLEEP button on the remote. The TV will turn off automatically 30, 60 or 90 minutes after the sleep button is hit. It can also get hit if you set the remote between seat cushions on the couch and someone moves, etc.
2) Does the TV get enough ventilation to allow heat in the TV to circulate away from the set? Drapes, tight cabinet, etc. The temperature sensor may turn the TV off automatically to protect the TV.
3) Your power cord is not well plugged into the wall or you might have some issues with the wall outlet - expecially if it is an older home (before 1980). Any wiggle of the cord may cause it to disconnect for a very short time - the TV will shut off.
4) This Brand is only available through BEST BUY and this model has a 1-year warrentee. The manual says to call 1-888-BESTBUY for service.
Good luck.
Please rate me.
Nov 23, 2009 | Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
We had no control of the DVD that we watched last night. No pause, fast forward, etc. Tonight, trying to watch another DVD and the one from last night continues to be playing and will not eject. Neith
Sometimes when you unplug the set ffrom the wall power or a while 1-2 minutes, and then plug it back in the problem will resolve itself. The DVD may eject. If it does, check it for damage, warping or dirt. If this does not fix it- you probably should take it to a repair center.
May 27, 2009 | Televison & Video
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
TV keeps shutting itself off!!!!
I think the problem with the remote control it malfunction take the remote control away from the tv
and test the tv
I had the same problem and one time the tv came on by itself
now i took the remote control away and testing the tv
now for 15 min. so far so good
try it and let me know
or call sony 1--800-222-7669
email me dnae@cox.net
thanks
Dave
May 24, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
TV WENT OFF BY ITSSELF
This TV has reached the end of its (short) life. Needs to be replaced.
You can try looking at what kind of TV it is, what model, and look at the manufacturer's web site, check for the manual, look up what it means when the green light flashes. Might be a code that means something but I think the TV is dead.
May 15, 2008 | Televison & Video
Wont turn on at all...
read info at ctechnicians.com email for questions
Dec 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
This may denote a proble in either your switching powers supply or your Horizontal section derived high voltage power supply. These are both very dangerous sections in your television. My next question is important; do you have a background in electronics? If not I would not advise you working on this problem yourself and that you take the TV to a repair shop for servicing. If you do have some background in electronics, I would like for you to make the following obeservations: What was the TV doing (it actions)prior to it going out? Did you hear any sounds before it went out like buzzing or crackling? What do you hear when you try to turn it on now, clicking? These questions are just to develop some background into what might be happening to your set. Thank you, Shuttle83
Oct 07, 2007 | RCA 32V524T TV
Televison & Video Logo
144 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
