Question about Akai PDP4225M 42 in. Plasma Television
AKAI PDP4225M HAS RED LIGHT BUT WILL NOT POWER ON.
I've pulled the power supply board but need to obtain schematic to properly repair. The fuse is not blown.Found bad 5.6 ohm 1/2 watt resistor at R001 and replaced.Relay at RL002 activated when power switch was turn on then immediately turned off.Checked resistor again,it was bad again.I'm sure it is a cap issue.Have you diagnosed this problem before? If so, do you know which caps to replace?(Power supply MPF7410 A)
Reggie4565
  • reggie4565 Nov 13, 2008
    Thanks but I can get the board for $109.00. This is a project for me thats why I asked for the schematic.I want to repair board myself. Do you have the service manual?
    Thanks,
    Reggie
    Master:
  • 691 Answers
This is because R001 is not 5.6 ohms, it's 560K ohms
Posted on Jan 11, 2011
2 Suggested Answers
  • 191 Answers
SOURCE: AKAI PDP4225M HAS RED LIGHT BUT WILL NOT POWER ON.
hi isolate ur power unit out replece ur resisitor & every other burnt items then check the schottky diodes in the secondary side &the electrolytic capacitors if bulgge or leak. if all this are ok , power then use voltmeter to test ur output voltages if ok , unplug your inverter  & power
Posted on Nov 10, 2008
Akai lct2721ad wont turn on red light in on
Whn you try to power it up does it attempt to power on before going red or does it just stay red? If it just stays red then its definitely a case of faulty power supply board. The easies way to resolve this problem would be to replace the power supply board, which can be obtained for about 50-75$ from shopjimmy.com. So let me know if you wish to fix it yourself
Feb 03, 2011 | Akai LCT2721AD 27 in. LCD Television
Tv turning on and off constantly, pitchure won't even come on.Akai Model pdp4225m
Power board is dead.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2010 | Akai LCT2715 27 in. LCD Television
My akai pdp4225m 42inch plasma went out. when i turn it on i dont get the blue akai splash screen. just black. any ideas on what part to order?
You may have one or two problems, the power supply has failed or the Y-Sustain board has failed also. The more common problem is the Y-Substain board if fails the most in plasma television, next comes the power supply then the X-substain board, My best solution for you is to check the power supply first and consider ordering the Y-Board also, the PS is usually the center board and the Y-Board is to the left of it. The X- Board is on the right side..
Dec 03, 2009 | Akai PDP4225M 42 in. Plasma Television
My Akai pdp4225m does not turn one green light is on but no pic or sound..There is a double clicking sound when I try and turn it on also when it does work it shuts off after and hour or so..Any info would...
Power supply filter capacitors and smoothing capacitors have warped. There will be some bad FET's, Diodes, and pull-up resistors too that need replacing. You can send us the board and we can repair it for you if you like.....
Your having a DC switching and regulation problem, its very common in these Akai models. I have repaired over 800 Akai LCD tv's so far since 2006. they all seem to have had the same fault scenario related to a similar problem like the one your having....
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
CWR-on_line Tech Rpt
Oct 29, 2009 | Akai PDP4225M 42 in. Plasma Television
Akai TV troubleshooting
power supply problem or screen needs re-gasing or another board fault call up manufactuer and request repair as it will still be under warrenty
Jan 17, 2009 | Akai PDP4225M 42 in. Plasma Television
Akai PDP4225M std/by red light only
1st your power supply needs replaced. But you could have issues with the sustain boards and or your panel that is causing your power supply to fail. once you replace your power supply you should be able to power up the set, but if you don't get a picture then you will have to trouble shoot the sustain boards and panel.
Jun 30, 2017 | Akai PDP4225M 42 in. Plasma Television
Nov 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai pdp4225m 42 in plasma
Stevenson
The problem is the main input digital board. You need to replace that board. I can help you find the board, if you interested. Please, e-mail at Stevebuy31@hotmail.com
Sep 09, 2008 | Akai PDP4225M 42 in. Plasma Television
Akai PDP4225M 42 in. Plasma Television Logo
424 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
