Question about Dell Dimension 2400 PC Desktop
Compputer shuts down abruptly
While using the computer the fan begins to make aloud noise and begins to spin faster and then the computer shuts down abruptly. when I try to start it immediately it shuts down again. After a while it stays on longer and then shuts down .
  • 153 Answers
It sounds that you might having problem with your power supply unit, try replacing it with another working one. Problems like this one can be caused by defective power supply unit.
Posted on Nov 10, 2008
Fan on Dell M5030 Starts on startup and then shuts down but computer continues to boot
Lots of fans are variable speed. Meaning they spin faster when the computer is hot and slow down when not. It's most likely spinning down. If the fan was bad the computer will either shutdown or generate an error during BIOS and halt the boot process.
Jan 11, 2013 | Dell Inspiron M5030 Laptop
Aspire Aspire SA10 is shutting off abruptly. I have to remove the power cord for 5sc then plug it back in, but this cant be good, help please
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 07, 2012 | Acer Aspire Computers & Internet
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
I have a KENMORE WASHER MODEL 11020894990.The slow spin comes on and works fine but when it stops to begin the faster spin it makes a klunk klunk noise and will not spin.
Well the klunk-klunk is the Break grabbing, to stop it, as it is detecting, what it thinks, is some sort of Unbalance or Overload, or detecting a motor fault, etc, real or not, and is shutting itself down because of this.
Feb 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Toshiba Satellite a70-s256 fan issues
Instead, turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air.
Give your computer a "blow-job", to remove all the dust that has accumulated inside your computer.
The dust has been acting as "insulation", forcing the fans to run faster, and with more noise.
Cooler computer -> quieter computer.
Jan 16, 2010 | Toshiba Satellite A70-S256 PC Notebook
Fan makes a lot of noise, then computer suddenly shuts down
Seems to be overheating. When you say the fan makes a lot of noise, do you mean an unusual noise or just that it is on high?
Feb 10, 2009 | Acer Aspire 5002WLMi Notebook
If you have recently fitted new hardware. Take it out.
If not, buy a power surge protector from your local pc store
Jan 30, 2009 | 2005 Mercury Villager
GE Washer does not reach full spin speed...stops abruptly
HI thanks for your question. the G E washer has to get rid of all the water before it starts to spin. check to see if you have a good water flow on pump out. if not clean the pump . thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | GE Washing Machines
2001 dodge durango
need a new water pump
Aug 25, 2008 | 2001 Dodge Durango
COMPAQ Presario SR1220NX - Heat Sink/Fan
The processor fan should always be spinning; the variance is how fast it is spinning to dissipate the heat. The audible you would hear was most likely the fan spinning faster.
Take off the side of your case and turn on your PC. Is the processor fan spinning?
Also if it is a fan issue you will begin to experience heat issues on your processor that will start to force your PC to shut down in order to protect itself. I don't suggest you allow this to continue to happen as you will eventually fry the processor.
Jul 10, 2008 | HP Computers & Internet
Dell Dimension 2400 PC Desktop Logo
195 people viewed this question
Alun Cox
