Question about Jetway (Avidav Serial) LCD-M1731SF 17in Multimedia LCD Monitor (Black) Built in Speakers Retail ***F...
Sound Everything works on the computer except the sound and its turned on
0 characters
1 Points
Monitor just stopped working
What is the make and model of your monitor? Sounds like your power supply has failed.
Jun 07, 2012 | Computer Monitors
My COMPAQ FP5315 LCD Monitor has built in speakers but i cant use them... can someone tell me how to fix this?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Nov 12, 2011 | Computer Monitors
I am trying to find a remote code for the Cox 7820 remote, that will fully operate my Hannspree tv. The codes provided by Cox will operate most of the TV functions, on the correct buttons, all except for...
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Oct 25, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I purchased a new computer and after hooking everything up, everything works except I have no audio. I believe the speakers are internal to this monitor.
Double check that you have the speaker cable plugged into the proper jack (audio out - green) on the computer. Make sure that the audio hasn't been muted and that it is set for the correct output type (if you have a multi-channel audio option).
Try a standalone set of speakers to check if the audio driver for the on-board audio or sound card is working.
I hope this helps.
(I've found that the integrated speakers will fail before the monitor does. Since the integrated speakers are low-end and similar speakers are fairly cheap, get new speakers of a quality you like. Repairing the speakers isn't worth it.)
May 19, 2010 | AOC LM729 17" LCD Monitor
How to turn volume up on my LG flatron monitor??????????
there dont have speakers yo, so you need a separete adio
Oct 27, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
Computer crash no sound
check the printed circuit board, check for cut lines
Dec 14, 2007 | HP Compaq FS 7550 17" CRT Monitor
Jetway (Avidav Serial) LCD-M1731SF 17in Multimedia LCD Monitor (Black) Built in Speakers Retail ***F... Logo
24 people viewed this question
Top Jetway Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Jetway Computer Monitor Expert? Answer questions, earn points and help others
