Question about Reddy R155D Utility Heater
Blowing smoke After my heater has run for a while, it will start to puff out smoke. I have to turn it off & wait for a while to turn it back on, but then it starts over again. What could be wrong with it? Thanks!
  • 1 more comment
  • Anonymous Jan 06, 2008
    Reddy Heater will fire for approximately 40 seconds then flame goes out and puffs smoke and shuts down. Unit is reset and the unit repeats the same thing.
  • Anonymous Jan 08, 2008
    After my heater runs for a while it quites burning and blows out smoke. What could be the problem?
  • lorenzolovat Jan 30, 2009
    same thing , with a 110,000 ready heater
Had the same problem!
Solution was so obvious I could have kicked myself in the pants.
Seen that the flame kept blowing out as if there was too much air so I constricted the airflow from the rear and it worked great. Then I realized that I never put the rear cover back on. Duh!
Put the cover on and BINGO! Seems to work just like it was designed.
Don't ya just hate when you have all those extra parts left over when you put things back together again?
Posted on Sep 22, 2008
  • 944 Answers
Heres the link for the manual and service centre list etc. http://12.153.20.74/manuals/118536-01A.pdf I had a quick look and couldn't see anything obvious from the info you gave, but maybe you have seen other symptoms/causes etc. good luck Pleased to help more if you need Hope this helps :)
Posted on Mar 01, 2007
SOURCE:
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Heater fires up and runs every once in a while it will stop flame goes out puffs smoke and fires back up also will run irregular
check ignitor element. sometimes they rust and get loose. replace if element is loose. this causes an open and the ignitor fails putting out the flame and then the safety kicks on turning off the heater blower.
Dec 15, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
HARD START AND BLOWING SMOKE
clean all of your filters and the spark plug and go back to useing K1 kerosene. Diesel fuel has a higher ignition temp. burns dirty and has a tendency to gel.
Jan 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
Wont stay lit
when unit lights only runs 10 sec then shuts off
Oct 27, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R155D Utility Heater Logo
133 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
T bone 1963
cavs1
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
