Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
I just installed my clarington 52" ceiling fan.low speed and medium speed work but high speed turns the fan off and the light dimmer doesnt work at all...feeling a bit like tim taylor here, please help.
  • 3 Answers
How many terminals does the terminal connection has and how is the main power connected to the terminal block? How is the capacitor connected?
Posted on Nov 10, 2008
Casa endeavor 52" lost high speed and low speed
Check the capacitor. If the fan is a remote you probably need a new receiver.
Jul 02, 2013 | Dryers
Replaced fan switch but fan only works on low and high but not work on medium
You have a problem with the connection to the medium speed motor winding, or a problem in the motor. Turn off power to the fan, open it up and verify that the wire nuts are properly installed.
Nov 14, 2011 | Hunter 52" Ceiling Fan With Light And...
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Not working
How old is it? If it is more than a couple of years old, the motor windings for highest speed probably failed. They can not be repaired as cheaply as buying a new fan.
Jul 18, 2008 | Hunter 28096 Westminster 52" Ceiling Fan...
High speed only 60rpm
I too just installed a 68" Altura and noticed a huge difference in fan speed. I spoke to a rep for the manufactorer and found out that the high, medium, and low rpms are 70, 45, and 25. The typical 52" fan has rpm speeds of 190, 130, and 75. The kicker is airflow. The 68" moves 7,808, 4,417, and 2,953 cfms on high, medium, and low; the 52" fans move 5,503, 4,087, and 2,509 cfms.
Jun 10, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Mar 10, 2008 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
185 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
