Question about Frigidaire 26" Built-In Electric Cooktop - White
Rear eye want come on
I have a glass cooktop that i replaced a limit switch and a rear element and the new rear element stll does nt work but when u cut on rear element the front element warms up
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds as if you have a wiring issue, somehow power is backfeeding into the other switch. aliitle too late but was the switch an exact match or was it a new substituted aprt, its possible that the manufactue either sent wrong part , or the new switch altough appears the same ,,wire terminals were in different locations
Posted on Nov 10, 2008
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
I replaced what I thought was a bad 9" heating element on my Kenmore glass top stove and the new element still does not work or even attempt to come on. what should I do next?
Did you check if electricity was coming to the element. Try putting a volt meter on the two wires and turn it on see if you get anything...could be a bad switch
Sep 15, 2014 | Kenmore Frigidaire Glass Cook Top...
One of the burners on my kitchenaid cooktop will not heat up. What do you think the problem is? Is this something that can be easily repaired?
If it is not a glass top stove, with the power OFF, and cold, pull out a working element of the same diameter and install it where the non-working element was. Try it now. If it works, replace the heating element. If it does not, check for voltage at the element connector. CAREFULLY. Worst case is that the switch requires replacing.
Dec 17, 2009 | KitchenAid 32 in. KECD805 Electric Cooktop
Coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
Jun 07, 2009 | KitchenAid 30 in. KECC506R Electric...
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Jp 989 switch replacement
not timely but no.
i have a dead switch, had to unhook it cause it kept tripping the breaker. 3 out of 4 work now.
can i buy 1 switch or do i need a whole new assembly. where to buy online ?
Aug 09, 2008 | GE 30 in. Profile JP989 Electric Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Frigidaire glass cooktop
first try putting pans on top and see what they do you should not operate these type of eyes with nothing on them as you will burn out the sensors in the eyes if nothing is there to reflect the heat back to them if it does the same thing with pans on them then you will have to replace the elements
Feb 11, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
New Whirlpool Cooktop Problem...Maybe.
The function 3 element are normal / depend to the intensity adjustment / the small 4th element are set for pre heating w/out burning , try to sdjust in lower adjusment or ann switch for pre heating.
Dec 04, 2007 | Cooktops
Frigidaire 26" Built-In Electric Cooktop - White Logo
66 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
