Why am I having trouble with my Epson Stylus Photo Printer R320 reading the new SD card that I recently purchased. Printer says that card cannot be used with this printer. ?? Is my printer now obsolete? Thanks in advance.
  • 1,879 Answers
At the time your printer was manufactured, it incorporates/uses what technology is available.
Things to consider, memory cards now comes in different capacity and speed. Your printer's memory card reader can't read cards that uses newer technology.
You can however use your computer's card reader if there is one or purchase a USB memory card reader to download the photos and print them from the computer.
This actually how I print photos since I can do a lot more before sending it to the printer. I use Picasa (free) for quick photo fix and effects.
Posted on Nov 10, 2008
I need to have epson stylus photo r320 resetter...please
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 25, 2011 | Epson Stylus Photo R320 InkJet Printer
Lines in My Pictures
This can happen if the printer cartridges were replaced recently but calibration / alignment was not done
Also the quality of output selected can also have an effect
Feed slippage can also play a part but were I you I would check these two items first and report back if these do dot help resolve the issue.
Aug 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Micro SD card
Open your computer scan w/ anti virus that SD card /try insert again to your printer .
Jan 05, 2008 | Epson Stylus Photo® RX620 InkJet Printer
Epson stylus photo rx560
Do you at least have all of the cartridges installed even if they are empty?
Nov 09, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson r320 printer will not read any memory cards
Does the green light come on when you insert a card? Most likely that if it can not read the cards, and it is just not your PC failing to communicate with the card reader, then the mainboard is probably faulty. If it's in warranty get Epson to replace it. If not, you could see if you can source another R320 from eBay, (or similar) that has a different problem and swap the mainboards. You would also need the service utility to do this as you MUST change the print head ID on the new mainboard. Another alternative is to simply buy a cheap card reader and plug it into the USB input port on the printer. If the mainboard is faulty, this may not work though. Still you could then just plug the reader into your PC instead.
Aug 18, 2007 | Epson Stylus Photo R320 InkJet Printer
167 people viewed this question
jasbo
jasbo
