Question about Brother CS-8150 Computerized Sewing Machine
How do I disassemble my Brother CS-8150 to get inside to find a nut that fell in there?
    New Friend:
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Posted on Nov 10, 2008
  • 2 more comments
  • WmBucher62 Mar 04, 2011
    Thanks, I was able to open the case following your directions. Was not able to resolve the bobbin not winding however your tips on the hidden screws were verm much appreciated. Thanks
  • deepgoat
    deepgoat Jul 09, 2012
    What is the support bar ? I got everything else.
  • flyred77 Jun 07, 2014
    The bar on the bottom that helps stabilize the machine.
  • Michelle Feb 06, 2015
    Flyred77, I have a similar machine and cannot separate the case at the front corner near the bobbin winder. Is the CS-80 included in your service manual by chance?
I need several parts for my brother CS8150
sewingpartsonline.com
a1sewingmachines.com
sew4less.com
sewvacdoctor.com
ebay
Apr 19, 2012 | Brother CS-8150 Computerized Sewing...
Bottom thread from theh bobbin is in big loops.
Problem with Brother CS-8150 Computerized Sewing Machine
bottom thread from theh bobbin is in big loops.
I have a CS-8150 as well -it was fine until I decided to clean the shuttlecock and I thought I had put it back correctly. However, it was after replacing the shuttlecock in place that my bobbin thread was making big loops and no matter what tension it kept doing it. So I removed everything out of the bobbin area. Cleaned and made sure that the shuttlecock was exactly in place as per the manual. Guess what it does not make big loops any more.
Just a suggestion.
Sep 09, 2011 | Brother CS-8150 Computerized Sewing...
I have a cs-8150 and I have lost the booklet for it how do I get a new one?
Hi msmrray...
Go to the following webpage and download your user manual for your brother CS-8150 sewing machine.
Please take time to rate me
http://www.manualsmania.com/model.php?model=66a0d4d518daf77c376aa16f509a92572ce18ec
Aug 15, 2011 | Brother Sewing Machines
My sister has gifted me a sewing machine. it's details are here--brother made in taiwan, 120v,60hz ac, 90w ,listed sewing machine ,ul 273c...i don't know how to use this machine..it is working with...
Hi
Manuals for Brother machines are usually available from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
They have one for the CS-8150 but I'm not sure if this is your machine or if the model number is UL273C.
The manual for the CS-8150 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_8150_EN_183.PDF
The manual for ULT2001 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ULT_2001_EN_200.PDF
Maybe one of them is similar enough to your machine.
Hope this helps!
Oct 28, 2010 | Brother CS-8150 Computerized Sewing...
My bobbin winder stopped working on my Brother CS-8150. spindle locks in, motor runs, but it seems that the winder is slipping. Can this be adjusted?
I think that I would call Brother at 1-877-276-8437 and ask them if this is a warranty issue. They may have a quick fix for you.
Oct 24, 2010 | Brother CS-8150 Computerized Sewing...
Wanted a maintenace manual
i was able to fnd manual at www.ifixmachines.com
Jan 25, 2010 | Brother CS-8150 Computerized Sewing...
I need to know how to change the bulb on a brother ps 33 sewing machine!
Hi, thank you for using FixYa! I don't see a model PS-33, however; you posted in the CS-8150 machine section, the link to the manual for a CS-8150 machine is attached. It has a section for winding and installing the bobbin and another section for upper threading. If your machine is not the CS-8150, please comment with the correct model number (PS machines start at number 1450 and increment upwards). If this is the correct manual, would you please take minute to rate this solution? Thank you! Gregg
Mar 29, 2009 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Computerized Sewing Machine Logo
384 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
