Question about Dryers
Frigidaire Dryer. Model-FER231CAS2 year 10/03.Doesn't dry colths.No heat
  • 178 Answers
SOURCE: HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Posted on Mar 18, 2008
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
SOURCE: running but not heating up to dry
Does the Ignitor heat up? If not, the timer might not be telling the gas system to start.
If the ignitor is heating up, and there is no gas, it may be a wiring problem or a gas valve problem. Need more information to solve.
Next step if ignitor is working, is to check to see if voltage is being sent to the gas valve.
Posted on Feb 18, 2009
Maytag317
  • 1136 Answers
SOURCE: No heat - long time to dry clothes.
Hi, Is this an electric dryer? The model# shows that is it. If it is gas, you need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $27.95. Our # is 1 866 798-4375 Make sure and check the venting to the ouside and make sre that it is clean and has no kinks.
If I can assist you further, please let me know.
Thanks
Vic
Posted on May 15, 2009
cj2176
  • 520 Answers
SOURCE: dryer trips breaker after 10 minutes using low or high heat
Start at the source. See if your breaker is big enough to handel the load for extended periods of time. A dryer uses a large amount of amps and can wear out a breaker that is not big enough. A dryer breaker should be 50a or 60a or if it is it may just be worn out. If that's not it then you may have a bad element. This is the part that makes the heat. You have to pry the front top of the dryer up and tilt it back. The element is on the back of the drum. It's shaped like a disk with a small tab on each side to screw it down. Hope this helps. Good luck.
Posted on Aug 30, 2009
My frigidaire fer231cas2 makes a horrible loud noise after its been running for 10 or so mins
There are rollers that the drum sits on. The roller surface or bearing can go bad causing the noise.
Aug 26, 2014 | Frigidaire Dryers
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Hi, My dryer has stopped dying the my cloths is this a common problem?
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Aug 31, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 11, 2011 | Dryers
I have a Frigidaire Dryer Model#FEQ1442ES0
heatman101
Aug 02, 2011 | Frigidaire Electric Dryer
Frigidaire dryer model fern7800ds0 doesn't heat
heatman101
Jul 14, 2011 | Frigidaire Electric Dryer
Doesn't heat or dry
Hi! jroqqow
The simpilest sollution may be one of the breakers is tripped, if its a electric dryer. If its Natural Gas or Propane, it could become even more complex. Best to check the dryer vent and make sure there is adaquate air flow out this vent. Let me know some clarification, Model Name, Number, electric, gas?
InMrFixIt
Jun 19, 2011 | Frigidaire Dryers
Frigidaire Dryer Drum Making Noise When Turning
that big spring in the back of the drum is your heating element.the part number is 131553900.not sure where to get it up there but marcone appliance parts in st louis missouri might be able to help you out ther phone number is 1-800-482-6022.good luck with your dryer i hope this helps
Sep 07, 2009 | Frigidaire Dryers
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
110 people viewed this question
Top Dryers Experts
