Question about Zanussi WJD1667W Front Load Washer / Dryer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Bit of a strange one so i hope someone can help...please? First happened yesterday and had an E20 message appear. Turned it off and on and it came back with the machine on pause half way through the cycle...so i unpaused and left it...came back and my mother had visited, and found a similar issue so turned off the machine. When i turned it back on it just had 3 straight lines on the digital readout...and the washing was soaking. So...i put it on a quick fast spin just to dry the washing but it just seemed to go round slow for 4 mins and left it as wet as it started. So...I turned it off and then started it from scratch again over night..(I am starting to think this is a software issue??) and it started fine so i left it. This morning i came back in it had errored again. Turned it off and on again and it was this time flashing on pause and 29mins left showing in the readout. This seems wierd as i am getting errors during the cycle and also it not going into a fast spin as well... Anyone any thoughts? Gratefully appreciated! IAn
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Posted on Oct 31, 2006
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hoover se 230 works perfectly except will not perform fast spin. (nothing happend when programmer dial is turned to fast cycle position
hello any spin problems can be caused by the module control board usually sits at the back of the washer may have a load of wires coming off it hope it helps
regards
shaun
Apr 22, 2011 | Hoover SE230 Front Load Washer
I have error 6E on my samsung washer
If during the spin cycle, the error code could be an error with the printed circuit board assembly of the washer. This means that the temperature readings are incorrect and the error will continue to display.
E6 error code indicates that the water heater is heating water too fast. Press the power button once to clear the error and finish the cycle before repair.
Check this link with additional info: original/457.jpg?1285349415
Hope this helps.
Apr 18, 2011 | Washing Machines
Maytag FAV6800, Stops at 34 minutes and will not stop, finish or unlock.
Hello AlpineCA,
I believe you are failing in spin cycle but that’s a wag without any error codes to go on.
With no error code it will require a bit more troubleshooting. If you start a Quick Wash cycle with minimal spin/soil settings I believe you will stop at the 21 min mark.
Not sure what wash cycle you are in and Spin/Soil settings for that cycle but I believe this is the spin cycle of that wash cycle (34 min).
I assume the washer did not pump out the water. The FAV6800A/FAV9800A is designed to start in the spin cycle with a fair amount of water in the wash tub so I assume you have water in the wash tub. You can enter Service Mode and turn on the drain pump to pump out the excess water. I’ll attach the process at the end of this post.
Before we do that let’s gather some info for troubleshooting. I want you to do a Spin Only cycle with that wet wash load. Let me know if the Cycle completes. The FAV6800A/FAV9800A machines suffer from chronic clutch malfunctions which will cause failing in Spin Cycle usually with dC/uC unbalance errors. Can you complete a Spin Only cycle?
My standard links for the DIY’er and can you let me know if you want to DIY the fix? Some folks can’t tolerate the down time and if you feel your aren’t qualified then I would recommend a qualified repair service. I’ll work with you until you decide to pull the plug on the DIY process.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
Pump out the excess water in the tub when failing in Spin Cycle;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
I’ll check back from time to time for your response. This board will not auto notify by e-mail of your response and most recently won’t let me post pics for troubleshooting support.
If you are going to DIY and we have no error code to the display the next step is to remove the front cover of the machine start up a Spin Only cycle and see if the motor will turn the clutch pulley CCW. Just be careful of the belt and follow safety warnings in the Service Manual…..Rich
If you want to work on this a bit quicker e-mail me at dh1200s@yahoo.com
Dec 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Neptune Washer displays D-C when it is in the spin cycle
If your are failing in that part of the cycle with dc/UC errors and you have no grinding noise or belt screech (possible hard failure of the clutch) then the clutch may just need some maintenance clean up. If you are failing in spin cycle with dc or UC errors or both this is what I believe is happening. I feel the tumblers in your machine are trying to rotate in spin cycle because of a clutch malfunction. If you can do the maintenance I discuss below or have a friend that can help perform this maintenance it may just solve your issue. After I did thiis clutch maintenance I can wash a single pair of socks or a full load of bath towels and the machine works as designed. Prior to that maintenance fix I could only complete a wash cycle if there were no clothes in the wash basket. I will try to help you solve this and hopefully extend the service life of your machine. Look at the Service Manual page 47 and see what is involved in the clutch removal. It's not too bad just a tight work area. If you want to give it a try I can supplement the manual info. You can download the SM from this site. FAV6800A/9800A Service Manual
Good luck, Rich.
My Mainteb fix performed in mid Dec. 08
""I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine without trying a fix. ""
Mar 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Duet. Strange noise and F 02 error code
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer top load model WDSR4110T
the agitator is the spline insert . that you can replace. The spin problem is in the clutch which is a bigger job
Dec 11, 2008 | GE WBSR3140DW Top Load Washer
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer just fills up and that is it
Sounds like a winding on the motor is burned out or the timer is defective. The motor uses a low power circuit during the delicate cycle both during wash and spin. The timer selects which winding is energized (fast or slow).
Feb 05, 2007 | Maytag LAT3600A Top Load Washer
Zanussi WJD1667W Front Load Washer / Dryer Logo
208 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
