Question about GE WPGT9360EPL Top Load Washer
GE profile Harmony Washer rotor assembly removal
Mine makes a groaning noise (bad bearing). Bought replacement. Attempetd to remove the old by taking off the 15/16 nut, removing motor cover and stator. Removed all bolts that attach the rotor assembly to the bottom of the tub as well as the single screw that is inside the tub. Would not come off. What part am I missing?
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
brainyass
  • 242 Answers
SOURCE: 1993 Jeep Cherokee Front Rotor & Pad Replacement
This is a walk through for a 1993 2wd.
1. Jack up and remove tire
2. Remove 2 brake caliper mounting bolts
3. Remove caliper and hang out of way with wire
4. Remove rotor, if stuck hit on all sides with a rubber mallet until it breaks loose.
5. Install new rotor
6. Remove old pads from caliper
7. Using a c-clamp and a block of wood against caliper piston, compress piston until it is flush w/caliper
8. Install new pads in same location as old pads
9. Reinstall caliper, may have to nudge it into place with rubber mallet
10. Reinstall tire.
note: There are no bearings to grease. You must replace the entire hub assembly if yours are worn.
Posted on Sep 11, 2008
SOURCE: Ball Bearing Replacement
when spinning , it is noisy. How to overcome it.
Posted on Nov 25, 2008
SOURCE: the 13/16 nut that holds the tub down keeps falling off
II suspect it is bad design, imagine that. We are having the same problem. After replacing the nut and using lock tight on threads, it worked two days and loosened again. My next attempt will be to "stake" the nut in place. This involves using a chisel and hammer to lock the nut in place by deforming the nut and shaft with a 90 degree dent. A second alternative will be to drill and install an allen head screw to lock shaft threads to nut.
Posted on Jan 04, 2009
How do i replace bad front wheel bearing ?
Replace the hub assembly which can be bought for $58 to $100 from various sources.
REMOVAL AND INSTALLATION
  1. Raise and safely support the vehicle.
  2. Place jackstands under the cradle and lower the vehicle slightly so the weight of the vehicle rests on the jackstands and not on the control arms.
  3. Remove the wheel assembly.
  4. Insert a drift punch into the rotor and remove the hub nut/washer.
  5. Remove the brake caliper, support and the rotor.
  6. Using the front hub spindle remover tool, separate the halfshaft from the hub.
  7. Remove the hub/bearing assembly-to-steering knuckle bolts and the hub/bearing assembly. To install:
  8. If replacing the seal, drive the seal towards the engine. Cut the seal off the halfshaft; be careful not to damage the halfshaft boot. NOTE: If the speed sensor bracket is removed or loosened from the steering knuckle, the speed sensor gap must be adjusted. If the speed sensor is removed from the bracket, speed sensor wax must be applied to the sensor before it is reinstalled in the bracket. Failure to apply the wax will permit corrosion and may result in sensor failure.
  9. To install the new grease seal, lubricate the with wheel bearing grease and using the hub seal installer tool, install the seal.
  10. Install the hub/bearing assembly-to-steering knuckle bolts and the hub/bearing assembly. Tighten the hub/bearing assembly-to-steering knuckle bolts to 70 ft. lbs. (95 Nm).
  11. Install the halfshaft to the hub.
  12. Install the rotor and caliper.
  13. Install the hub nut and washer. Tighten to 183 ft. lbs. (245 Nm).
  14. Install the wheel assembly.
  15. Remove the jackstands and lower the vehicle.
Jul 03, 2010 | 1996 Cadillac DeVille
Washer makes a grinding noise while running in the wash cycle. I've confirmed the rotors in the unit are not hitting anything inside the tube. The noise seems to be coming from the drive mechanism...
You will likely have to remove the pump motor from underneath to solve your problem. Try removing the lower spray arm assembly down to the deck and check the pump impeller for noises. Make sure to note the position and placement of all parts removed. Hope this helps!
Jun 28, 2010 | GE 24 in. Profile PDW7800 Built-in...
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
NOISE DURING SPIN CYCLE
You have to take the tub out, take off the rotor from the bottom of the washer, remove 4 bolts and take off the stator, take off the bearing retaining nut, then drive the 2 bearings out with a drift. I bought the bearings online for 20 bucks from a supplier (VBX). They are standard metric bearings number 6005 and 6006. I put some silicone grease on the shaft seal and drove the new bearings into place. Then reassembled, and the washer is whisper quiet.
Jul 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Jan 03, 2009 | GE WPGT9360EPL Top Load Washer
93 honda accord rotors
Your Accord has what is called "Trapped Rotors". They actually fit behind the hub. The procedure to remove them is not complicated, but it is time consuming.
Here is how I do it:
1) Remove axle retaining nut.
2) Remove brake caliper and bracket.
3) Remove lower ball joint retaining nut and use pickle fork to loosen spindle from lower ball joint.
4) Remove axle from hub.
5) On the back of the spindle, remove four bolts that attach hub/bearing to spindle.
6) Use slide hammer to remove rotor/hub assembly.
7) Remove 4 bolts attaching rotor to hub.
8) While it is a snug fit, the hub bearing does slide through center of rotor to remove it.
Installation is in reverse order.
A bad bearing usually makes a growling noise while driving.
Jun 06, 2008 | 1993 Honda Accord
Harmony Profile washer
Hi: If you can put the machine to it side down and remove the motor rotor assembly with a 15/16" socket and pull gently to put appart the rotor and with a 5/16" socket remove the clutch assembly you can see if the center gear is broken. Let me know
Sep 30, 2007 | GE WPGT9360EPL Top Load Washer
GE WPGT9360EPL Top Load Washer Logo
96 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
