Question about Whirlpool Ultimate Care II GSQ9669L Top Load Washer
Whirlpool Ultimate Care II still won't drain
Thanks for your advice about our washing machine. We removed the cabinet, checked the drain pump and sure enough, found one of our daughter's socks. We put it all back together and did a test run with just water and it drained - but when we actually tried a load it wouldn't drain. Any ideas? Thanks so much for your help, Andrea
  • Whirlpool Master
  • 3,361 Answers
More than likely you have another garment in the pump or connecting drain line.
Check it all again.
Posted on Mar 27, 2009
How do you open a top loader
You have to hinge console back by loosening screws in back corner of console. Then remove two gold clips that hold cabinet on. Pry with flat head screwdriver. remove wiring harness from lid switch and the whole cabinet will pull forward
Jun 13, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
May 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer began leaking. what should i check for?
check the water pump. you will need to remove the cabinet to see. once you can get the cabinet off, it is usually easy to replace the pump.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I take off Whirlpool Washer cabinet to get to the pump
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
click on your model number. The new window will give diagrams in the left-hand side.
Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Not draining and leaking from bottom
this unit uses a direct drive pump ( no belt connection , so if our motor is running you should be able to drain water, it s possible a small item has gotten into you pump, and has locked it up and not leaks. the top of you rmachine doesnt pop off, the entire cabinet actually comes off to gain acess. you can also tip the machine back and look underneath to see possble cause of leak. many videos on you tube showing access to the pump , easier to watch then try to explain how to do it , not hard at all though
Oct 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Ultimate Care II -- No Drain/No Spin
not a major project..remove 2 screws in rear of console lift and roll console back ..remove plug in cabinet to switch and pop clips out each corner ..cabinet can then be lened forward and removed allowing access to switch
Aug 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
http://www.fixya.com/support/r397092-replacing_water_pump
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Jun 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultmate Care II won't drain
You will have to remove pumps hoses and make sure they are not clogged.
May 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSQ9669L Top Load Washer Logo
274 people viewed this question
Dan Webster
Dan Webster
Sal De
