we moved and our hot tub too. it was working fine. we have not wired it up here at our new home and it keeps turning it self off wont go above 51and display reads Dry? jets wont turn? what are we missing?
-   I am having the same issue. Service guy is coming in 2 days. Fortunately all pumps and heater are still under 5 year warranty for me. I will post what the issue was...-   langer00
Nov 30, 2008
-   FLO is displayed, even though I set a higher temp, it wont heat and jets barely work ?!? a symbol that looks like a lock is displayed - did I lock something by accident?-   zena8million
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and...
(More)
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and flame works, but no heat. Unit only worked for a few times, then this happened. How can I troubleshoot to see what part needs to be replaced. Thanks.
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but...
(More)
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but neither pump works. Both fuses are good. Electrician just checked them. No reset on pumps. Any ideas?
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve...
(More)
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve problem ?
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with...
(More)
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with a slight hissing noice but the smell of propane is very slight. The propane tank is full and functional and I have cleaned out the top section where the gas is emitted. Has the regulator gone bad or is there another issue?
