Question about Dell Latitude D505 Notebook
Dell 505 Laptop cover removal
I am attempting to remove the cover. I have removed all screws but it still appears to be attached at the back. i do not want to force it, any ideas?
  • Del Sol Crt Nov 10, 2008
    My actual task is to get to the AC power source plug. when attempting to use AC power the plug connection to the inlet reguires pressing and holding it tight to the inlet to maintain a connection.
  • Del Sol Crt Nov 14, 2008
    Is this worth fixing? On the dell web site they do not even address the ac jack as a potential problem nor do they appear to sell a replacement. I hate to lose a decent and originally expensive laptopp because of a malfunctioning ac jack.
  • Dell Master
  • 998 Answers
Here is the link to the Latitude 505 laptop service manual: http://support.dell.com/support/edocs/systems/latd505/sm/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 10, 2008
  • Walter H Boehm Nov 10, 2008
    The AC jack is soldered into the motherboard. To gain access to it you’ll have to remove the motherboard.
  • Walter H Boehm Nov 14, 2008
    Dell does not sell individual components like the AC input jack. The only options you have is to take in to a local PC repair shop and see if they can fix it or purchase a replacement motherboard.
How to reseat then harddrive
I'm unsure of why you would need to reseat a laptop hard drive - but it's easy to do in most laptops. Usually there is a rectangular cover on the bottom of the laptop - usually only 2 screws securing it. Remove screws, Remove cover, unplug hard drive, plug hard drive back in, replace cover and screws.
Apr 28, 2014 | Dell Inspiron Computers & Internet
My laptop shuts down in 5-10 mins.
Instructions
Purchase a new fan for the Sony Vaio model you have by checking the owner's manual of your computer or consult the Sony website for the correct part number.
Remove the power cord from your computer and then remove the battery. Unlock the battery and slide it from the bottom of the laptop. Allow it to sit for 5-10 minutes after removing the battery.
Turn the computer with the left side facing toward you and locate the only screw found on the left side and remove it. Remove the panel by sliding it toward you and set it aside.
Slide the panel covering the power buttons to the left and detach the ribbon cable connecting it to the motherboard and then remove the panel gently.
5
Remove the keyboard by unscrewing the small screw directly above the keyboard. Once the screw is removed, gently lift the keyboard and detach the small cord connecting it to the motherboard. Set the keyboard aside.
6
Remove the plate under the keyboard by unscrewing the three screws and lift the plate out.
7
Disconnect the cooler fan from the motherboard by pressing the connectors in and removing them from the sockets. Once the connections have been removed, lift the cooling fan up out of the computer.
8
Replace the old fan with the new one you purchased and attach the two connectors. Reinstall the metal plate back on top of the fan and attach the screws.
Jan 10, 2013 | Dell Inspiron 1545 Notebook
I have dell inspiron 600m laptop. When I boot my laptop, initially display comes on panal for a sec and then goes off. laptop is loading windows and everything works fine. But, I can not see the display....
try going into safe mode,remove the drivers reboot ,if you are able to see windows you have driver problem,if not your inverter is bad this a small board which sits under the lcd bazel.ONLY ATTEMPT THE FOLLOWING IF YOU FEEL COMFORTABLE OTHERWISE GET A PROFESSIONAL.If you are going to tackle this make sure the battery is removed the ac as well.now your lcd has rubber feet covering some screws remove the rubber feet you will see the screws remove the screws carefully remove the plastic bazel by prying it away with your fingers
the inverter sits below the lcd make sure both cables are snug.Usually sometimes its the conector on the right that comes loose.
Good luck
Aug 29, 2009 | Dell Inspiron 600M Notebook
Left hinge busted
Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
Jul 28, 2009 | HP Pavilion dv4000 Notebook
1 Solution for "dell inspiron 8600 laptop how
The hard drive is behind the cover where the mic and earphone are located. Turn the laptop over and there is a single screw that secures this cover. Remove the screw then slide the cover and hard drive out. The cover and cradle are attached to the hard drive.
May 08, 2009 | Dell Computers & Internet
Dell W1700 picture went out. Still have audio.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Nov 29, 2008 | Dell W1700 17 in. HD-Ready LCD Television
How do you take the hard drive out of a dell latitude cpx J650GT
on the bottom of the laptop there should be four screws un screw those and take the cover off next take the keyboard and top covering off then carfully remove the hard drive which should be loacted near one of the fans.
Nov 26, 2008 | Dell Latitude CPX-J Notebook
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Dell Latitude D505 Notebook Logo
398 people viewed this question
Alun Cox
