Question about Nikon F65 35mm SLR Camera
I have two different lens one is stronger than the other.Sometimes I take the perfect picture then other times not so good.How do I know which lens to use for close up or i want a distant shot at a cl
Nikon camera will not click over after bout 3sec, i have to close shutter to take another shot
  • Nikon Expert
  • 362 Answers
Do you mean that, you press the shutter release once and the shutter stays open until you press the shutter release a second time. If so, check your shutter speed setting. If it is set to "T" (Timed Exposure) the camera is working correctly. Change your shutter speed to an appropriate setting, such as 1/125. If that does not solve the problem, you might need to take it in for repair.
Posted on Nov 18, 2008
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
Dec 18, 2015 | Canon EOS Rebel G 35mm SLR Camera
Is it important to change fragrances according to the different seasons of the year?
Yes, since heat increases the intensity of a fragrance. There are certain fragrances that are more appropriate for summer and other stronger scents that would be better for winter use. A good guideline to follow is to wear lighter scents in the summer and stronger in the winter. Citrus scents are perfect for summer while orientals are better for winter.
Nov 23, 2010 | Health & Beauty
Fungus (oil spray/mist?) on inner lens surfaces - how to disassemble and clean a Canon 75-300mm EF AF lens? A skeleton picture would also be helpful. Thanks, Tom.
Okay. I just wanted to scare you away from ruining a perfectly good (or nearly so) lens, but a learning project is a different matter. And a lens collimator is not that hard to build. One source is the book "Camera Maintenance & Repair" by Thomas Tomosy. I'm sure a quick Google search would show even more.
I did the same thing myself decades ago, taking apart a damaged zoom lens. Unfortunately, I never got it working properly again :-( But it was an educational experience, even though I didn't have a lens collimator...
Nov 13, 2010 | Canon EF 75-300mm Lens
I thought batteries were low. Replaced. Camera will not "boot up". The power lite comes on. It , however, immediately goes off. I replaced batteries 3 times, but now the lens will not retract...
Check to be sure you have put the batteries in correctly. Sometimes with wear, you may have to reinsert them. Also, depending on where you got your batteries, such as a bargain place or a discount store, the batteres may not be good or good enough. Digital cameras take a stronger battery than most cameras.
Nov 06, 2010 | Sony DSCWX5 Digital Camera
Only pictures taken indoors show up on the display
Obviously there's too much light getting through the lens. Either you have locked the iris down with switching the wrong switch or changing something in your on screen menu. If you have your manual check for some mention of over or under exposure. What you are getting is overexposure.
This could of course be caused by a problem in the camera itself. More than likely in the iris control. An Iris stuck in an almost closed position would cause this as well. Luckily the problem is a user error (nothing personal) I caused a similar problem in a $40.000.00 broadcast camera and took me about 15 minutes to figure out which switch I'd bumped. If the camera has been well looked after and not subjected to sand, grit and heavy dust and the lens works OK then it's a good chance of being a user error. Try the troubleshooting section and if you have no joy it looks like a trip to the repair shop. It's certainly nothing which can be fixed by proxy. But sometimes, I repeat sometimes, a slight tap on the front of the camera body using just your finger may move the iris and release the jam. Don't tell anyone I said that. I've actually done it myself and as far as I know the camera is still working but don't keep bashing it and if the friendly tap doesn't work then don't try anything stronger. Let the tech have a look instead.
Don't forget, I never said a word. Shhhhhh!!!
Apr 20, 2010 | Sanyo VPC-E760 Digital Camera
Disc play interrupted
I recomend that you clean the lens to see if that makes a difference.
Also you might want to look at my Tip on dealing with DVD's that jump.
Apr 05, 2010 | Mintek DVD-2580 DVD Player
What is CCD?
A CCD is the Charged Coupling Device. It is the IC chip that scans image from the lens into binary data so that it can be stored onto your memory card. Sometimes they can have different results in light because they are photo senstive and can burn out. That is why it's very important never to shoot pictures in direct sunlight with these unless you have a filter becuase the direct sunlight can burn out the CCD unit.
Jul 04, 2008 | Cameras
Everytime I take a picture it turns out blurry
Inside the lens their is a focus motor that has to be perfectly set if it get out of ajustment this will cause a blurry image it you try to zoom some times you may get a lens error this is because the lens has been obstructed from the inside by the focus lens. the lens eather needs to be replaced or may find a broke one off ebay with a good lens pretty cheap if you are going to try and repair it your self.
Mar 20, 2008 | Mercury Electronics CyberPix S-555V...
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Camras Broke
Hello This is a pretty usual type of problem. The lens assembly is composed of some lens and some servomotors that will move them around or focus them properly in order to get a sharp picture. This is a delicate part of any camera. Sometimes one of the small parts in the lens assembly get out from their positions and damages or jams other components there. Therefore when you start the camera it produces weird noises as it tries to extend the lens. A camera doesn't know where the lens are at the moment you start it. It will power up the motors for a small amount of time, as it knows that if the motor works for about 1-2 sec the lens should move and extend. If this doesn't happen the camera gets confused and gives you errors or makes strage noises as it powers on the motor but it can't move the lens because they got jamed or are fully extended. Only a service center can fix this because lens mechanisms are very fragile and require specialised hardware to be realigned or repaired. In your case it would be adviceable to ask them an estimate of the repair, for you to know if it's worth it. It can be a simple job like putting back the piece that got out of place, but also it can be a situation in wich the whole lens assembly must be changed because of extensive damage recieved when the motor forced the lens to extend. It is also a good thing to do, NOT to power on the camera anymore as it can damage itself furthermore. Sorry as I can't give you more detailed tips, this isn't the do-it-yourself type of repair, even the service centers are having problems with this repairs. Good luck however, maybe it's a simple thing.
Mar 18, 2007 | Samsung Digimax S500 Digital Camera
Nikon F65 35mm SLR Camera Logo
64 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
