Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
30'000 btu spark style will not lite
It has sit for several years with fuel in it . I changed the plug and it will lite with the cover removed and restricting the fans air flow to the ignighter side of the nozzle. It has run for appox 1-3 mins but as soon as I remove the baffle restricting the air flow it will go out again. We have drained the tank and placed 1-5 gal of kerosene in the heater
  • Morrismat101 Nov 10, 2008
    Which of the adj screws is the air adj screw ? every thing else looks good . noozle is clear and filter (foam moon shape has been cleaned and dried . There does not appear to be a fuel filter in either of the supply lines
  • 232 Answers
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Posted on Nov 10, 2008
  • Jerry Magee
    Jerry Magee Nov 10, 2008
    Look again. There IS a fuel filter, unless some body over the years has robbed it.
    This link can instruct you about the ajd screws better than me
    http://reddyparts.com/pressure.htm
    Post the exact model number. Maybe, I can provide a breakdown.
IT WILL CRANK BUT WONT START,,,, 98 FORD ESCORT,,,REPLACED FULE PUMT,,,HAS A LITE SPARK FROM QUOIL
check your spark plugs, usually you need change it every 30,000 miles...
How to change?
http://www.ehow.com/video_110_replace-spark-plugs.html
Hope this helps
Sep 20, 2011 | 1998 Ford Escort
My 2001 Lincoln Continental has been sitting for over two years, It did start for about a minute but it wont start again. what can I do
BATTERY DEAD MORE LIKELY.CAR BEEN SITTING FOR 2 YEARS GAS IN FUEL TANK WEAK FULL OF WATER, YOU NEED TO REMOVE DRAIN OUT OLD FUEL IN THE FUEL TANK. YOU NEED ADD NEW FUEL IN FUEL TANK,CHANGE FUEL FILTER, IF CAR BEEN SITTING FOR TWO YEARS.I WOULD REMOVE SPARK PLUGS ONE AT A TIME REMOVE EACH SPARK PLUG SQUIRT FEW DROPS OF OIL INTO CYLINDER THEN REINSTALL SPARK PLUG, REASON I SAY TO DO THIS PROCEDURE IT HELP PISTON RINGS SEAL UP ENOUGH TO BUILD UP COMPRESSION SO YOU CAN START THE ENGINE WHERE IT BEEN SITTING TOO LONG.YOU NEED CHANGE ANTIFREEZE AND THERMOSTAT.REPLACE RADIATOR HOSES TO BE ON THE SAFE SIDE,REPLACE AIR FILTER.
Jul 30, 2011 | 2001 Lincoln Continental
Will not light getting fuel through nozzle ignition lites changed fuel
maybe getting to much fuel is there away to turn down fuel or does it have a hot enough spark plug
Jan 26, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a lp 75-125 reddy heater. when pluged in it no longer sparks to ignite fuel. I have the style were the ignitor is always sparking an arc.
The tranformer that sits under the motor for the igniter could be burnt out. You can use an ohmmeter to check it. I'm assuming yours has a spark plug. Make sure it isn't fouled and has a gap of .050".
Dec 25, 2010 | Reddy 30m Btu Lp W/th Heater
100,000 miles maintenance for a 1998 mercedes benz slk
No such schedule.
spark plug every 30,000 miles
fuel filter/filter element every 60,000 or 4 years
brake fluid every 2 years
cooland every 3 years
oil changes between 14000 or more the FSS indicator on the dash will tell when need to be change
May 09, 2010 | 1998 Mercedes-Benz SLK
Heater wont lite
It sounds like you are having an airflow problem since it lights fine with the cover off. You need to adjust the airflow the burner or look for some type of obstruction.
Apr 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
How often do i need to get a tune up and what parts do i need to buy for the tune up?
once or twice a year is good for an actual tune up which is new fuel filter, plugs, plug wires, & antifreeze.
About every other year, you should replace tranny fluid and filter. Not bad idea to have coolant and tranny flushed every 2-3 years too.
Sep 30, 2009 | 1999 GMC Sonoma
Change spark plugs
spark plugs at 100,000 miles,( average driving) fuel and air filter every 30,000 miles, air filter more often if driven in dusty conditions
Mar 06, 2009 | 2000 Dodge Durango
Change spark plugs
My 2004 Verona had factory installed "NGK BKUR6ETB" regular spark plugs which I replaced at 30,000 miles. The 2005 model year is supposed to have Iridium spark plugs. To replace the spark plugs: 1. Remove plastic top engine cover. 5 nuts 10mm socket. 2. Unplug connector from each ignition coil. qty 6. 3. remove 2 hold down bolts per ignition coil. 10mm socket. 4. remove ignition coil, lifting straight up. 5. Spark plug is now accessible, use deep well 5/8 spark plug socket to remove.
May 15, 2008 | 2004 Suzuki Verona
Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Feb 16, 2008 | Dayton 511 Utility Heater
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
233 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
