Question about Dishwashers
Kenmore 665.16529000 after a normal wash cycle we find dishes with food particles in the upper basket. i took off the arm underneath the basket and examined it but did not find anything unusual with it. any suggestions?
  • 14 Answers
SOURCE: upper arm does not spray
Dig deeper, until you find filters. Those are probably clogged. You may need a screwdriver...
Posted on Dec 29, 2007
SOURCE: upper basket spray arm
Have you checked that the cover for the water inlet at the top where it connects to the spray arm is attached? It could have worked loose. Just re-attach and your spray arm should "miraculously" start rotating again!!
Posted on Aug 26, 2008
  • 117 Answers
SOURCE: Kenmore 665 15899 dishwasher won't clean
Make sure the filter inside the dishwasher is cleaned out and read about my advice for dishwashers for more tips.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Posted on Feb 25, 2009
plnolte
  • 62 Answers
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
Posted on May 12, 2009
  • 3 Answers
SOURCE: food particles remain on dishes
This was fixed on my unit by taking out the chopper assembly and cleaning the screen. There is full spray on top now. The screen on the chopper assembly actually had some plastic on it that was hard to see, but was blocking most of the holes. Since this was blocked, the pump couldn't pull enough water to push it to the upper spay arms. My chopper was actually broken so it wasn't clearing the screen, so I had to replace it. That will probably help prevent this from happening again, but if you ask me, the unit was designed poorly for handling normal debris that comes off of plates. I'd recommend inspecting this regularly to keep it clean.
Posted on Sep 27, 2009
Food particals only on the upper shelf
Sounds like either the upper arm is clogged, or unable to move. Make sure nothing is in the way and that it can spin freely. Then, get lemishine machine washer (at grocery store) and run a cycle through - if it's hard water filling the holes, that'll solve it. Sounds too simple - but it actually worked for my exact machine.
Mar 09, 2014 | Ariston Technologies LI640S Dishwasher
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
I have soap build up in the dishwasher. The dishes aren't getting completly clean. Ran load today twice and they didn't look any better.
Most likely causes are:
Hope this help. Good luck.
Sep 11, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Unclean dishes food particles left on glasses
Sep 11, 2009 | Dishwashers
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
Sep 11, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Food particles and what looks like sand consistently left on dishes after cycle is finished
Clean the filter.  It is at the bottom below the wash arm.  Remove the wash arm by lifting it off.  The filter is a round ring the can be lifter out and cleaned.
May 20, 2009 | Dishwashers
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Film and food residieu remains on upper rack
Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
Good luck.
Oct 04, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Dishwashers Logo
Top Dishwashers Experts
