Question about Home
Toilet valve shuts off before tank is full
My shutoff valve keeps closing when tank starts to fill
  • 43 Answers
This means your floater is too low, what you need to do is adjust it so it sits higher,
if you have the kind with the ball on the end then you simply need to raise the ball alittle and adust the screw,
if you have the kind with no ball, then there is a little floater attatched to the fill valve, kind of looks like a slide hammer, (if you know what that is) just lift up on that there should be an adjuster screw somewhere close to it lift up a little and adjust where its needed..
anyone at lowes in the plumbing department can elaborate. and hopefully make it more vivid for you
Posted on Nov 16, 2008
My Briggs Stratton float bowl will not fill up.It is near new and has been flushed with carb cleaner. Engine runs if I spray gas into carb, then dies.
Is there fuel in the tank?
Is there a shutoff valve between the tank and the float bowl that is closed?
Is the shutoff valve vacuum operated? If so then there could be an air leak that prevents the valve from opening.
Mar 10, 2017 | Briggs Garden
What would make a snow blower run for 15 minutes then shutoff, restart for 30 seconds and then shutoff again?
Buddy of mine had a arise brand with a tecumpsi motor it was bought new. Believe it or not, the exaust valve stem was just a little long made that way from factory. When it would warm up the valve would expand just a little and create low compression. Then the thing would be impossible to keep running. Took it apart and filed the valve stem down and it runs like a champ again. Good luck!
Feb 04, 2015 | Measuring Tools & Sensors
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Gas leak from carburetor into bottom of air intake elbow. Filled empty gas tank and within seconds after opening the shutoff valve under tank, gas started to drip from bottom of intake elbow. Shut off the...
It sounds like the needle valve in the carburetor is not seating properly to shut off the fuel. A badly worn needle or dirt/debris in the needle seat area can cause this. Disassembly of the carb and a good cleaning will be required.
Sep 04, 2011 | Garden
1981 Honda CT110 trail. Runs perfect for about 5 miles then dies. Starts a couple times each time slowly idling down until it dies then it will not start again for until it sits for an hour or so. I...
It sounds like you still have dirt floating around. What did you coat the tank with? I used POR-15 with great results. Install a gas filter that you can see through and see if you are still getting dirt from the tank. Check the new carb for dirt. It sounds like something is somewhat plugged which allows gas to slowly fill your carb after it sits. But this clog is what causes your bike to stop after 5 miles. Does your tank have a shutoff valve? Run a line from the valve to a jar and see how well the gas flows. The shutoff valves usually have a screen....check it for dirt.
Nov 26, 2010 | 1982 Honda VT 250 F
I have an American Stadard Toilet that is only 2 years old. The toilet will not stop running. Could you give me some trouble shooting ideas?
There's a lot of variety in the works in the toilet tank. Assuming this is not a pressure-assisted toilet-----First understand the three valves are: 1. The shutoff valve - on the supply line coming into the toilet tank. 2. The fill valve - inside the tank, opens with the float descends, closes when the tank fills up. 3. The flush valve - inside the tank on the bottom. Common old style is a flapper on a pivot. Yours may operate straight up and down rather than on a pivot.
Three very common problems are---- 1. The chain that connects the handle to lift the flush valve is getting caught, not allowing the flush valve to close. 2. There is problem with the flush valve being able to get a good seal when it closes - could be debris or misalignment. 3. The fill valve is not closing when the tank is full, could need adjustment or there is debris preventing the valve to seat. . Here's are some steps to diagnose---- close the shutoff valve. Wait a few minutes as you watch the level in the tank. If the water level decreases, you have problem with the flush valve. To confirm the fill valve as the problem, turn the shutoff valve back on. Lift up on the float that is supposed to turn off the fill valve. If it shuts off, you should be able to adjust it - most have a +/- plastic adjustment screw. But if raising the float by hand only slows it down, you have problem with the seating of the fill valve - which can sometimes be cleaned, but more often would need to be replaced.
I hope this is helpful. Thanks for using FixYa.
Apr 02, 2010 | American Standard Home
Compressor motor only comes on and fills tank when tank is empty. When tank has any pressure it tries to start but stops.
there is a valve under the regulator, at switch off pressure the valve must blow of the air between cilinder and checkvalve after stop running.. when checkvalve is not closed it keeps blowing.
Feb 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Hi, I have a colt Mk 282 air compressor that won't auto shutoff. eg the compressor keeps running on trying to fill the holding tank even thou it is full!! it will then blow the rear saftey plug out of the...
The shutoff valve (usually has a set of contacts like a relay) is probably stuck. For the most part, these are not adjustable. They can usually be removed, cleaned, and reinstalled to correct the problem. Sometimes that permanently fixes it. Sometimes, you have to bite the bullet and by a new shutoff valve.
Mar 20, 2009 | Air Tools & Compressors
Home Logo
519 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
