Question about Olevia LT23HVX 23 in. LCD Television
DON'T TURN ON -OFF
HI ! I HAVE A OLEVIA HD TV. MOD: LT23HVX IT WAS WORKING FINE BUT YESTERDAY I CAN'T TURN ON ,ONLY BE STAND BY WITH A RED LIGHT IN THE CONTROL PANEL. WHAT I NEED TO DO OR REPALCE. THANKS.
  • viento86 Nov 11, 2008
    HELLO!! I HAVE A OLEVIA 23" BUT IT DON'T TURN ON&OFF SO WHAT I NED TO DO
  • Olevia Master
  • 19,396 Answers
The TV is in protect mode.
Try unplugging power cord for ten minutes or so, and see if this help.
If the TV does not restart, then try unplugging for longer.
If still no luck then that means that there is an internal fault, let me know if you get the led blinking a number of times, or if there is an error code message on the TV display.
Posted on Nov 11, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Unplugged power cable from back of tv (unplugging wall plug would probably accomplish the same) for 15 Min., plugged it back in
thanks
good luck
    Scholar:
  • 112 Answers
If you have the capibility of opening it, check the wires running from the power button to the circuit board. If everything is fine there, there is a short or a problem with one of the boards and would have to be professionally serviced.
    Brigadier General:
  • 6,966 Answers
On similar concerns, the standby light or the red light would be flashing indicating that the unit has switched to protection mode. On some models, the number and sequence of flashes indicates the general area of the fault and where initial diagnosis can begin. Eventually the unit has to be opened up for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Incidentally, in the hope that this is a simple glitch, perhaps you can try unplugging from the mains and removing all connectors. After an extended period, reconnect and verify connections and try again.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 11, 2008
    Additionally, was there anything out of the ordinary prior to the incident such as power failure/interruptions, thunderstorm, TV used for an extended period pf time, the remotes has been inadvertently played with, or anything noteworthy.
  • 685 Answers
It might be a short it would be best to try to trouble shot it
Tv won't turn on no blue light either
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Olevia LT23HVX 23 in. LCD Television
My lt23hvx power button does not work. I keep pressing the power button to turn on and it will not turn on
If you're trying from the remote control, then try from the TV and see if it works. Or vice versa... Also, make sure the TV is plugged in (you would be really surprised to see how often this is a problem).
If there is no noise and no lights, then odds are your power supply is faulty. For that tv, you're looking at a replacement of less than $100.
Cheers, -SJ
Mar 08, 2011 | Olevia LT23HVX 23 in. LCD Television
I have 19" Olevia LCD TV and the red power light comes on when you plugged it in but the TV DOES NOT power on
You only have 5v standby voltage circuit working. The problem can be i nte main power supply or the main control board that send the signal to the main power supply to turn on. Those are the two place to look for.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Hooked to pc....starts up fine at
check your hd settings are correct on your pc.
Apr 28, 2009 | Olevia LT23HVX 23 in. LCD Television
Red lite comes on but tv will not power up.
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching, as my husband couldn't get it to work, but I could.
Apr 20, 2009 | Olevia LT23HVX 23 in. LCD Television
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia won't turn on.
I posted photos and a description of my solution for this problem here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/ There's another thread on FixYa dealing with this same issue that has a variety of solutions as well.
Mar 04, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia LT23HVX screen resolution
what kind of cable are you connecting with? If you are using a Composite or S-Video cable perhaps you may want to use the VGA cable instead and see if that corrects the issue.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
