Question about Kitchen Ranges
Maytag oven won't stay at temp.
I have a maytag gas oven 13 years old. It will heat to temperature but when the temp. drops, it doesn't kick back on to keep up to temp. Is this a thermostat problem? Sometimes it works fine, sometimes not.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
New ignitor is you problem part number 1240035, wont reignite after reaching temp, common issue with all gas stoves
Posted on Nov 10, 2008
Oven sometimes doesn't stay up to temp
The temp is controlled by electronics that monitor the oven sensor.
The sensor should ohm out at 1100 ohms.
If it is shirted to frame or open the open temp would not do right and the
oven control would not know what the temp was and would probably declare an F-3 error.
In your case I don't think that is the problem. What i think it is going to be is the ignitor. If it is getting weak it sometimes won't draw enough amps to open the safety bimetal inside the gas valve.
Probably the ignitor is on it's way out.
Jul 30, 2011 | Maytag CWG3100A Gas Single Oven
My Maytag Gas Oven will not heat up very much. It's a 50/50 guess if the oven will heat to the correct temp. Sometimes it works fine, the other times it is not very warm at all in the ove, even after...
ello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Maytag CWG3100A Gas Single Oven
No heat in gas dryer, gas good, elec good??
if the heat is on when the dryer is cold then shuts down after 15 to 30 minutes and doesn't lite for a long while you have bad gas coils,the gas should come on until it hits temp. then it shuts down,when the dryer calls for heat it will turn back on,if it stays on for short periods of time you might need to clean out the dryer,this will shut the gas down to soon,you need to clean out the duct that the lint filter slides into,blow out the vent line,make sure the air is blowing outside with nothing blocking it and vac out the inside of dryer where the motor is
Mar 12, 2010 | Maytag Dryers
Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Nov 22, 2009 | Hotpoint RGB745 Gas Kitchen Range
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Feb 08, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
298 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
