Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
KDF-70XBR950 Blue spots developing in 2005 sets
I just noticed a bunch of blue dots on my KDF-70XBR950 with manufacture date od march 2005. I'm in communications with sony now to see what they are willing to do. Obviuosly I need a new optical block which will rum me about $1200 to get fixed. The set cost me over $6000 new:( I'll keep everyone informed....
  • 1 more comment
  • Anonymous Feb 06, 2009
    My problem is exactly the same. The television was bought in 2005 and blue dots started appearing in 10/08. It's getting worse and half of the screen is turning blue.
  • denisericky Feb 10, 2009
    i have the same problem, first a blue haze across bottom, then blue dots that are becoming more everyday. called service but that model is not covered after june 08. hard to understand person, not very good english. doesn't seem fair when you spend almost $7,000.00 sony should cover this problem since it is a problem with a lot of their tvs.
  • Any Guy
    Any Guy May 11, 2010
    Sony WAS covering optical block replacements on this TV until June of this year, but that warranty extension has now expired. I wish you luck with their customer service department
SOURCE: Blue Dots
I have the KDF 42WE655 with the same blue dot issue and Sony upgraded me to the KDL 46V4100 for $375! I jumped on the opportunity.
Posted on Sep 02, 2008
ladywinn
  • 5138 Answers
SOURCE: Fixed Blue dots in central screen, blue fringe in lower left
You have a Bad Light Engine This is a high dollar part Call UED they may have a rebuilt one in stock 1-800-648-6657.
Posted on Feb 07, 2009
  • 184 Answers
SOURCE: Blue dots in KDF-60WF655
Yes, your optical block ( light engine) is bad. Heat generated by the lamp circuit with its poorly designed ventilation system, cause the LCD panels inside the light engine to fail. They are the size of a postage stamp. There are 3 LCDs, for red, blue, and green. The heat causes them to warp and de-laminate.
Sony has systematically downed played the scope of this issue. It appears however that virtually every LCD projector they make can develop damage in the light engine which is extremely expensive to fix.
I suggest contacting Sony and your state's attorney general's office of consumer complaints asking for action on this.
michtech
Posted on Feb 20, 2009
  • 121 Answers
SOURCE: blue dots on LCD screen
http://www.sony.ca/view/319.htm
Posted on Feb 25, 2009
  • 139 Answers
SOURCE: The blue line appeared at the lower border of the letterbox
easy fix. adjust the vertical position of the image using the on-screen menu.
Posted on Mar 06, 2009
Sony wega lcd tv blue dots
thats caused by the optical block which is very expensive to replace. Sony has had alot of issues with the blue dots on the screen its not worth repairing due to the high cost of the optical block
Feb 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture is yellow/blue (no red)
KDF means it is a LCD rear projection set so you likely have a problem inside the optical engine it uses or the associated box inside connected to and a part of that engine.
May 24, 2012 | Sony Grand WEGA KDF-70XBR950 70" Rear...
BLUE DOTS PLUSS RIGHT SIDE BLUE FUZ
need to replace the optical engine block to resolve thsi issue
Dec 18, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Blue blothes on LCD screen
Blue blotches spreading over the screen are failure of the optical block
contact Sony to see if you are eligable for a free repair.
Sony will cover the cost of the optical block repair (parts and labor) at no charge through December 31, 2008 for 2004 Model Year Grand WEGA™ Televisions with the blue spot problem.
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
http://esupport.sony.com/US/perl/news-item.pl?news_id=
Read more: Help from Sony for LCD rear projection with blue spots - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com http://www.hometheatershack.com/forums/sony/5351-help-sony-lcd-rear-projection-blue-spots.html#ixzz0gm8a3718
Don't bedeterred by the dating of this announcement, it is a manufacturing fault and they have been pr5etty good to a lot of people with the same problem.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Blue streaks on the screen of my kdf-70xbr950
This has a failing optical block. If you can do your own work there is a rebuild service on ebay
Feb 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
THE CORNER OF MY SONY 42" VVEGA IS BLUE AND HAS BLUE SPOTS
your light engine is bad call Sony and see if it is one of the models on extended warranty
Aug 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue spots
This is a Light Engine problem. Call a good TV Tech and explain the problem. These can be rebuilt for around $450. New ones are $800 to $1200.
Jun 30, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Mar 06, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Blue shadow
You have a bad light engine or in Sony TV sets, it is called an Optic Unit Block Assembly. This is a very expensive part and should not be attempted to be replaced by a novice. Call an authorized Sony repair place to have this repaired. Good Luck
Sep 14, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
292 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
