Question about Panasonic PT-LB10VU Multimedia Projector
I have the Panasonic PT-LB10NTE projector with wireless network (not on your list so had to put the VU model which is almost identical) Iv replaced the bulb in my projector and when i turn it on the green light flashes, then goes green but it doesn't project anything. it repeats this and then goes amber and the red lamp light flashes as if there is a problem with the projector itself. the bulb is brand new so it cant be that and im installing it correctly and screwing everything up properly. how can i solve this problem? is there a reset procedure for the lamp circuit or something? Thanks Simon Dale
  • morley86 Nov 27, 2008
    i contacted Panasonic about this to enquire about buying parts fom them and they said they will replace it free of charge as it was a fault on this particular model! and its 4 years old!!! sent it off tuesday evening, got it back thrusday morning. now thats service!
  • 59 Answers
SOURCE: The projector would not turn
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Posted on Feb 10, 2011
  • 231 Answers
SOURCE: I have been trying to fix our PT-AE300U. The lamp
could b ballast or powercsupply board
Posted on Apr 13, 2010
  • 1637 Answers
SOURCE: I have a problem with our projector. The model is:
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Posted on Jan 19, 2011
  • 59 Answers
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Posted on Jan 24, 2011
  • 88 Answers
SOURCE: I've just replaced the lamp
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Posted on Aug 10, 2011
I need a user manual for panasonic pt-ae200e
I can email you this manual. It is 34 pages. Please send email to Please put PANASONIC PT-AE 200E in the subject line. I will send it to you right away.
Oct 16, 2011 | Panasonic PT AE200 Multimedia Projector
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Network adapter not found when running wireless program
Sounds like the Apple Dealer is onto the right idea.Unfortunately wireless control for projectors is still in it's infantcy and subject to compatability issues. A complicated alternative is to "Try" a wirless bridge adaptor in between the laptop and the projector. using the lan port on the projector, you would set up a mini lan between the projector and the bridge, and you would get a wireless connection between the mac and the bridge.
Probably too complicated, the extra cable may just be the go for now until panasonic release the firmware upgrade for you.
Good Luck in the Courtroom!
Jan 17, 2010 | Panasonic PT-LB80NTU Projector
We have a Panasonic PT-D5600U DLP Projector, and the rear infrared sensor is not working. The front sensor works fine, but the projector is ceiling mounted, and we need to utilize the back sensor from the...
Hello: in most cases, front and back sensors are identical. Might even be those little boards, as well.
I've seen repeated problem with sensor board circuitry, not a IR sensor, itself. in my 2 cases, there was a faulty sms ceramic capacitor, twice at the same make and model of Phillips TVs. If you can handle safely open and close top part of projector's cabinet, you will see those 2 small pc boards, connected to control panel. To get a part#, go to "", then look for "support", then 'parts ordering". enter your model# and you'll find whole list of the parts for your set. You don't need any authorization to buy 2 little assemblies. Get 2! The other one will quit sooner or later! shouldn't cost too much, anyway.
Good luck,
May 13, 2009 | Panasonic PT-D5600U DLP Projector
Ihave a panasonic projection model pt ax 100u
everything you need to know here...
Jan 04, 2009 | Panasonic PT-AX100U-EC DLP Projector
Cannot access menu screen on Panasonic PT-D3500U projector
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
May 28, 2008 | Panasonic PT-D3500U Multimedia Projector
Driver for the Panasonic PT-LB60NTU
To my knowledge, the Panasonic PT-LB60NTU's wireless connection to a MAC is not supported, sorry.
Kind regards.
Feb 07, 2008 | Panasonic PT-LB60NTU Multimedia Projector
Panasonic pt l711u power will not stay on
That used to happen to my PT 711U until I put in a new air filter. After that, no problem.
Dec 28, 2007 | Panasonic PT L711U Multimedia Projector
Panasonic PT-LB10VU Multimedia Projector Logo
640 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
