Question about GoVideo Go Video DVD/VCR Combo
Dvd will not eject manually or with remote tried unplugging and restarting it didn't help
  • DLCbreaks Nov 17, 2008
    My GoVideo wll not eject either. When it says'reading', I pull down on the front flap and sometimes it will open, but mostly not. Also, one out of 4 DVD's won't play. A bar comes up on the TV that says, 'unknown disc' .Everthing else works fine, so this is very frustrating.
It probably wasn't the best solution but it worked. I tried to jimmy open and pull out the dvd tray. When that didn't work I tried pulling the dvd out with needle nose pliers, but it did not budge. Finally I hit the eject button one last time and it worked. I hit the eject button a couple of more times and it did work. I did ruin the dvd, and haven't had a chance to play another dvd to see if it is working properly.
Posted on Nov 11, 2008
I put in a dvd into the dvd player, and went to eject it. I pressed the eject button and a "locked" caption came up on the screen. I dont have the owners manual and I cant figure out how to...
You may have enabled the child lock feature, try pressing the Return, Enter and Power buttons together to toggle the lock off. If this is disabled and you still can't open the tray, turn off the unit and unplug it. After 30 seconds or so, plug the unit back into the electrical outlet. Attempt to open the tray. If this does not solve the problem, try pressing Power + Stop + Eject buttons together. Also try pressing Disc1 + Stop + Eject simultaneously (if a disc1 button is on the remote or player).
If the error message is t - L C K or persists after trying all of the above steps, then you need the unit serviced.
The manual is available at the Sony support site: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPSR200PB .
I hope this helps.
Apr 16, 2011 | Sony DVP-SR200P DVD Player
Dvd player
hey, have you tried to unplug the dvd player for a while, also hold down the eject button on the player, if there is a small hole in the tray use a needle or other small object to eject the tray,
Sep 03, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Craig dvd player problem
unplug the unit for a while. then turn it on
Dec 02, 2007 | Toshiba D-VR600
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
Just bought the 26 inch with DVD. Put in dvd and it starts .. tried to stop it and eject the dvd, it froze up and won't release the dvd help!!!
Unplug the unit allow it to sit for a secound, then plug it back in. Try your eject button again on the remote and the TV if there is any. If this does not eject after power cycling the TV. My recommendations are if you just bought it take it back.
Nov 30, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Dvd & vcr DV2140
TRY UNPLUGGING THE UNIT FOR A FEW MINUTES.SOMTIMES THIS WORKS.
Nov 01, 2008 | GoVideo Go Video DVD/VCR Combo
A friend gave me a gift of CH-DVD 300 player.It is brand new.I opened it and got it connected to my TV.I inserted a photo CD in it.I viewed about 150 photo slide show very nicely.With the remote I tried to...
Greetings Ranin,
I would try unplugging the unit for approximately 30 minutes to allow it to completely power down and then plug it in again. It might restart the internal menus and allow the dvd player to eject.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Televison & Video
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
GoVideo Go Video DVD/VCR Combo Logo
134 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
