Question about Jenn-Air JES8850 Electric Kitchen Range
Stove is beeping and indicates code 000F meat probe
Stove is beeping suddenly and says remove meat probe, which is not even being used in the stove...tried unplugging the stove, but same problem when we start again. really annoying and can't get it to stop
  • Anonymous Dec 13, 2008
    after cleaning stove top constant beeping that I cannot turn off
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Posted on Sep 30, 2007
SOURCE: meat probe problem
Replace the oven sensor
Posted on May 11, 2008
  • 409 Answers
SOURCE: kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Posted on Sep 13, 2008
SOURCE: Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Posted on Dec 21, 2010
Error code 000f
Use a multi-meter to check the ohm's resistance of your temperature probe: should be 1100 ohms at room temperature = 72 degrees F. Range Stove Oven Temperature Sensor 12001655 Multimeter DM10T
After time, the connections between the temp. probe and the control board usually benefit from being disconnected and re-connected to keep corrosion from interfering with the resistance redings the control "sees" from the probe...
Jul 11, 2016 | Jenn-Air Ovens
Kenmore KGSA906 display shows unplug meat probe when probe is not inplace and now we dont have any oven use
That's a communication error . U may need to replace the probe. If that doesn't solve the problem, you will need to replace the erc.
Nov 14, 2011 | Kitchen Ranges
My whirlpool gas stove displays a message F4-E1 and beeps. What is causing this?
F4-E1 is meat probe malfunction. Check the probe over and remove it see if that clears it.
Dec 18, 2010 | Whirlpool Ovens
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
My meat probe on my jenn-air electric stove works but no beep
you may need to scroll through your settings to turn the beep on
Nov 25, 2008 | Kitchen Ranges
Kitchenaid Superba flat top range
we had the same code come up today; have you gotten a solution yet. we were not using the probe however the probe it was asking to set the probe temp.
Dec 23, 2007 | Kitchen Ranges
Jenn-Air JES8850 Electric Kitchen Range Logo
223 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
