Projection tv problem. The tv after about 6 hours or so cuts off. It's a phillips. We've had it for about 10 years but it just started having this problem. We thought it might be the verizon box so we changed boxes and it did it again today.
  • 728 Answers
You might have a short that occurs when the tv gets hot. It cuts off so it will not catch on fire. You will need to get it checked by a professional to get it fixed.
Posted on Nov 10, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Unplug the tv for ten minutes and then plug it again and check out.
  • mmechanics Nov 10, 2008
    also remove all the external connections from the back of the tv and check out if it is working or not.
    if it still does not works then it must be board error on the tv.
    either the capacitors or ics are blown or faulty.or the fuse is blown out.just replace that faulty components from the main board and it will work properly.
    thanks.
Phillips 47PFL422D/37 I've had the tv about 6 years with no trouble. But now the picture is to dark to watch it also pulses. I've tried to unplug it and plug it back in I get a picture for
First, average life on these sets is about 3 to 4 years at best and only boards are sold so even if you can pin point the board (no individual parts are sold) it is likely if will not get fixed and doing so is a bad investment as all the boards are now old.
Dec 04, 2012 | Televison & Video
I have a 2006 Sony KDF-55-E2000, just replaced the lamp and housing and now I have a green stripe at the top and a red stripe at the bottom. Is it worth having this set repaired if I do not have an ex
We had the same problem. Let it be and now the tv won't turn on. If I understand correctly from what I've read it's the optical block and they seem to be just as much as a new tv.
Jun 23, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Tv shuts off, red status indicator lamp flashes.
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Tv won't stay on
You could have bad STKs if so replace both of them.Big Black chips on convergence board.
Dec 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Phillips 60 in. rear projection approx. 10 years old
This is a common problem with the older models. The opt chip fails. You can get a repair kit at www.magnavoxhelp.com. After a few months of getting smaller and smaller the audio and video will go out but the power light will remain lit.
Aug 18, 2008 | Philips 60P8341 60" Rear Projection...
Hi, we have a phillips tv. it is about 6 orso years old. within the last 6 months, it has starting going off. you turn it on and it may play 5 or 10 or even 30 or more minutes but it keeps going off. the...
I wouldnt use that service man. If your set is shutting down its most likely do to the shutdown circuitry being triggerd by a defective component. I would recomend contacting someone skilled with phillips model televisions, most sets that play and then shutdown usually have a problem with a single component that is triggering shutdown, a skilled repair man will test the various voltages to determine the cause of the shutdown.
Jun 07, 2008 | Philips Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
