Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Reloading OS i cannot get my Ti-84 Plus silver to communicate with my computer. It started with the Garbage Collecting screen... that's been on forever. and I looked up how to get off that hoping to just crash it and reload. Is this possible and if so how?
  • 8 Answers
Apparently you can reset the calc if you remove a battery, hold delete and re-insert the battery....
However, try this...Find somebody with the same calc and connect them together. On the working calc Press 2nd, link [x,t,n], G: send OS and wait for good things to happen...
Posted on Nov 11, 2008
My TI-84 calculator says "Garbage Collecting" and won't work, how should I reset it?
Found at www.epsstore.ti.com
What can be done if a TI-83 Plus family or TI-84 Plus family calculator displays Garbage Collecting... for more than 20 minutes?
The garbage collection allows the cleanup of unused archive memory. It deletes unarchived variables from the user data archive and it rearranges the remaining variables into consecutive blocks. When a variable is unarchived, the Archive free memory amount increases immediately, but the space is not actually available until after the next garbage collection.
If garbage collecting is more than 20 minutes, the calculator has possibly locked up and will need to be reset.
The reset procedure will delete all the items that are in the memory of the graphing calculator. Use the reset procedure below:
• Remove 1 AAA battery.
• Press and hold down the [DEL] key.
• While holding down the [DEL] key, replace the AAA battery, and press the [ON] Key.
The message Waiting... Please install calculator software should appear. At this point, it will be necessary to reinstall the calculator's operating system.
• Connect the calculator to the computer using the TI Connectivity Cable or DirectUSB Cable.
Please post if this was helpful...
• In Windows®, click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
• In MacOS® X, open Hard Drive >> Applications >> TI Connect >> TI OS Restore.
• Follow the directions on screen to reinstall the calculator's operating system.
Access the link following for detailed instructions on how to complete operating system installation.
Oct 14, 2010 | Texas Instruments TI-84 Plus Silver...
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
Frozen ti 84 plus silver edition
Ther is no reset button. You have to take the batteries out.
Take the AAA batteries out and take the back up battery out...located in a little door with a screw just above the AAA batteries. Leave the batteries out for about 8 hours. This is how you reset a TI graphing calculator.
Aug 18, 2009 | Texas Instruments TI-84 Plus Silver...
Mirage os calc
yo i had the same problem, i ended up going back to os 2.40 - alot of times when oyu download mirage its from an unreliable source. the same thing happened to me cuz i wanted to play mario, but it isnt worth ******* up the insdes of the calculator man.
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
Error message for TI-84 Plus
Try and resolve this issue by re-installing the calculator's operating system using the TI OS Downloader. To do this, please follow the steps listed below. Be sure you have fresh batteries in your calculator.
1. Download the OS 2.43 file to your computer (preferably the desktop).
2. Open the TI OS Downloader by going to Start>>Programs>>TI Tools>>TI Connect>>TI OS Downloader. If you do not see TI OS Downloader, you may need to install the latest version of TI Connect. You can download a free copy from:
www.education.ti.com/downloadticonnect
3. From the main screen, select your calculator and cable type. Click "Next" to continue.
4. From this screen, locate the OS 2.43 file by clicking on the yellow browse folder and navigating to the location where you downloaded it. Double-click the OS 2.43 file to select it.
5. Remove one triple A battery from your TI-84 Plus. With the battery removed, press and hold the [DEL] key while you re-insert the battery.
6. You should see a "Waiting..." message on the screen of your calculator. If so, disconnect the USB cable from your computer, re-connect it and then click "Start Download". This should begin the OS transfer process.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
Garbage Collecting
graphing calulators work much like computers. The have RAM space so they can remember what you have done recently and stuff like that. So when it's garbage collecting it means it's trying to find more space. This generally means that you don't have much much ARC or RAM space left. You can see this under your memerory manager. (2nd + enter) then you can reset your calculaor(2nd plus 7 1 2) or you can go to memory manager and unarchive your programs. Fur an example you have TI 84. Most new TI 84 have sientific tools. so if you don't you it take away the archive (*) by pressing enter and then hit DEL. the more RAM space and ARC space should make it so it doens't garababe collect. Hope this works. i can help you more if this doesn't work. GOOD LUCK
Jan 24, 2008 | Texas Instruments TI-84 Plus Calculator
Ti os restore problem
you shouldn't need a username and password. Download the OS from education,ti.com.and right click it, there should be an option to "Send To TI Device..." That should work.
Oct 21, 2007 | Texas Instruments TI-84 Plus Silver...
Garbage collecting
I had the same problem. Here's whutcha do: You know that USB cable that came with your calculator that hooks up to your computer? You're gonna need it. First, take out one battery from your calculator. Then hold down the DEL button. Whilst holding it down, re-insert the battery. Now turn the calculator on. Hooray! It doesn't say Garbage Collecting anymore! Now it says "Waiting... Please install operating system now." Now you hook up your calculator to your computer with that cable. Go into TI CONNECT (if you don't have it, download it at TI's official website), and transfer the newest OS (also available at TI website). Now your calculator is working again. Woohoo.
Sep 24, 2007 | Texas Instruments TI-84 Plus Silver...
Garbage collecting
Sep 07, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
216 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
